Guest eva Report post Posted 12/01/2008 02:20 AM Hi, When VoiceGuide makes a phone call and get busy tone or no answer and have retried to call the number as many as the set amount of retry call, how can I get this to write to Microsoft Access table? FYI, I use VoiceGuide version 6. Thank you. Regards, Eva Share this post Link to post
SupportTeam Report post Posted 12/01/2008 02:44 AM You would need to update your system to v7. In VoiceGuide v7 it is possible to specify a custom script/command to be ran when the call is not answered, and also a script/command to be ran when the retries are exhausted. Share this post Link to post
Guest eva Report post Posted 12/01/2008 03:33 AM Is there any way to get around it without upgrade to v.7? Thanks. Share this post Link to post
SupportTeam Report post Posted 12/01/2008 03:52 AM The feature which you are asking about is not available in v6. You can only perform this action if you update to v7. Share this post Link to post
