Capture Customer Hang-up & Dbquery Issue
I am evaluating your software and I have two questions:
(1) Within your modules, how do I capture if a customer hangs up the phone. Currently the script I created has to run to completion before the line will become available to receive another call; regardless if the customer hangs up during the playing of the first module.
(2) I am receiving the following error in version 7.0.8
ERROR v7.0.3252.36547 (Wed 26/11/2008 20:18:14.16) vbsDBQuery_Run : Object reference not set to an instance of an object.
at ..(String strIn, String strSection)
at ..(Int32 iLineId_In, String strModuleTitle, String strOleDbName, String strOleDbConnectString, String strSQL)
I am utilize MS Access as my testing database.
I can run the script without any issues with version 7.0.6. My database Select and Insert statements work correctly. Once I upgraded to version 7.0.8, I started receiving the error. I have since reverted back to 7.0.6 so I can complete my evaluation.
Thanks for your help.
Please see: http://www.voiceguide.com/vghelp/source/ht...ll%20finish.htm
Trace files are created in VG's \log\ subdirectory.
Please post the vgEngine traces and the VoiceGuide script used.
Since I am new to the forum, when I post the zipped up log files, are other forum users able to view / download the files? or are they just available to the voiceguide support team?
Thanks.
