lidor Report post Posted 12/18/2008 10:36 PM Hi, I think i would like to puchase VoiceGuide. But since i dont realy understand a lot about VoIP, I have some questions. I have an Office with 3 phone lines. and I would like to buy Panasonic TRD600. (IP) Can VoiceGuide Connect to that ? and how ? Can I retrieve data from databases using WebServices, do you have an example ? thanks, lidor Share this post Link to post
SupportTeam Report post Posted 12/18/2008 10:58 PM The Panasonic KX-TD 600 supports SIP, so you should be able to register VoiceGuide as SIP extensions on the PBX. Details of how to register VoiceGuide with a SIP server (ie. the PBX) are here: http://www.voiceguide.com/vghelp/source/ht...ip_register.htm Can I retrieve data from databases using WebServices, do you have an example ? VoiceGuide can retrieve information from a Web Service. There is an example of how to do this in the VoiceGuide Help file, on this page: http://www.voiceguide.com/vghelp/source/html/modvbs.htm, see the "Retrieving data from a Web Service" example. Share this post Link to post
