Running Software For Mutiple Clients On Same Computer
Hello All,
I need to see if anyone has installed the software on the same machine for mutiple clients and how you have your clients log into upload there data or messages.
skip_davis72@yahoo.com
Thanks again
Separation of scripts for multiple clients on inbound calls is usually done by using ISDN systems and assigning different script to run depending on what is the DNIS/Indial number of the call.
On outbound calls the scripts to be used can be specified on a per call basis at the time when the set of calls is loaded.
If you can describe in more detail what aspects of multiple client setup you have questions about then we can provide a more detailed answer.
HI,
We have many clients on the same system. WWW.THEYCALLED.COM, depending on the number they called in on - we play different scripts. Its really easy once you try it. Our application is 100% data driven - we have over 750 800's and automation was the only way.
