Guest u4910 Report post Posted 01/09/2009 04:37 AM There are a couple of on-board switches on my Dialogic D4PCIUFW that I was wondering what they did. One is a dial that goes from 0-F and another red switch that is on/off. I haven't found anything in the dialogic docs. Share this post Link to post
SupportTeam Report post Posted 01/09/2009 04:42 AM 0-F is aboard ID switch. You can disregard if you only have one board in system. For multiple boards make sure each board has a different ID set. The red switch decides is the lines plugged into to card are 'on-hook' or 'off-hook' when the power to the computer is off (or card is not used). Share this post Link to post
