Different Logging Folder?
i have a question concerning VGs logging-system.
In default it creates all log in c:\
when running VG on a server 24/7 the c: drive will get flooded with log-file after some time.
is it possible to locate a different folder for logging purposes (e.g. in voiceguides root oder any subdirectory)? i would appreciate that very much.
thx for help
Logging was only meant for debugging purposes - it should not be turned on by default and can be turned off by setting in VG.INI :
[TraceLog]
LogToFile=0
and by deleting the C:\TapiWrapLogSelect.txt file.
(C:\TapiWrapLogSelect.txt is not isntalled by default either)
At this stage it's not possible to change the directory in which the log should be created - but having them junk up C:\ is a valid gripe and we'll have them moved to a directory "log" under VoiceGuide install dir.
