Guest Jonah Report post Posted 02/03/2009 07:36 PM I wanted to give you a working example of how I am using your API and receiving events in my VB.App to see if you are able to integrate Speech Rec in a way that will work with my existing setup. I have attached a zip file with a working example. Essentially I've modified your VGCSInterface app slightly and receiving events through that I capture all of the events within my VB app and am able to direct the call appropriately. A couple notes: 1. This uses VoiceGuide version 7.2 2. Put everything in a folder called c:\temp 3. Launch the EXE in C:\Temp\VGEvents_Test\EXE 4. Set C:\Temp\VGEvents_Demo.vgs as inbound script on line 1 VGEvents_Test__VoiceGuide_7.zip Share this post Link to post
