Vg7 + Hmp = Object Reference Not Set To An Instance Of An Object
I am trialing VG7 with the Dialogic HMP drivers (SU225 and SU237) for a VOIP-enabled solution. For now, I am testing using SJPhone in direct SIP mode from another PC to call the machine running Voiceguide. Calls are not be answered, with the following message in the vgEngine log:
131524.328  6   3       qScr  run   evCallerId EV_CALLERID, iActionID=0, crn=8000001[134217729|0|0|0|0][10.140.48.73||10.140.48.25|||]
131524.343  6   3 cid   LastCidMessage values [10.140.48.73,,10.140.48.25]
131524.343  6   3 cid   iCallerIdHasArrived=1
131524.343  6   3       AnswerTheCallIfAllowed iIvrDev=1, strDlgcDevName_Network=iptB1T1
131524.343  6   3 ERROR v7.0.3293.39631 (Tue 06/01/2009 22:01:02.03) EH_AnswerTheCallIfAllowed  : Object reference not set to an instance of an object.
  at vgEngine.modLineEv.(Int32 iLineId, Int32 crn)
If I click Hang Up on any of the 4 lines in Line Status Monitor, I see the following in the log:
131424.390 13           sockStatusLink_OnLineReceived [<request><type>hangup</type><port>1</port></request>] iLineDevicesControlled=4
131424.390 13     lscmd hangup port=1
131424.406 13   3       HangupCall ('and any associated'=False), source=LineStatusMonitorRequest, WorkModeScript=, linestate=[iDLE]
131424.453 13   3 ERROR v7.0.3293.39631 (Tue 06/01/2009 22:01:02.03) Line_Hangup_Main : Object reference not set to an instance of an object.
  at ..(Int32 iLineId, String strCallSource, Boolean bHangupAnyAssociatedCalls)
I have tried this on two different machines running WinXP SP2 with the same results. I did register for a trial key for the HMP drivers, so I see 4 lines in the line status monitor. Any thoughts? the vgEngine log is attached.
vgEngine.zip
Could you please update your system to this version of VoiceGuide: [old link removed]
This new version should fix the issue that you have encountered.
The file you posted appears to be incomplete. When I try to install it, I get a message that the installer integrity check has failed. The downloaded size is only 16,138,240 bytes.
Have just reuploaded that file and downloaded it and ran the downloaded version. The previous upload was not fully uploaded for some reason. The install is about 19.6MB.
