Dialogic Card And Voice/fax Modem
using demo 7.0
dialogic D/4PCI/U, intel6.1
multiple voice/fax modems
I configured the app to use dialogic board like to add additional voice modem/line devices
Can you provide sample config.xml
is it even possible ??
i am still in testing stage
the D/4PCI/U is not fax compatible...can it still be used to receive faxes..tried your record module setup to no avail
scouting forum to no avail
objective is to maybe use external modem in addition to D/4PCI/U to provide fax receive alternative.
thanks in advance
Not possible. You cannot mix Dialogic cards and voice modems.
No. You need a card that is fax capable. Every current model Dialogic card is fax capable. D/4PCIU is not a current card, it has been replaced by D/4PCIUF - which is fax capable.
Suggest you get a D/4PCIUF (or D/41JCT etc).
