Scrip Designer 6.0.3010
using your script designer,
where do I adjust settings for save window size or save last open window settings
instead of opening blank script it should open the last one I worked in.
I think these a fundamental user settings...
also wanted to search for script designer via this forum
it returned pages with just script or designer
I tried script+designer to no avail
I wanted pages returned containing "script designer" only
what am I doing wrong
its very hard to extract info from this forum searches return irelative information...
I would think its in your better interest to provide target information since most questions asked are redundant.
I should be spending more time on writing you a check to purchase this great software
rather than sifting thru outdated and irelative forum posts
thansk inadvance 4 you reply
v6 Script Designer does not keep track of size/position of last open window.
If you'd like to open a script directly then you can just double click on the script and setup and association for .vgs files to be opened by the Script Designer.
Most editors do not automatically open the last document when you start the editor itself directly.
The search on the forum is beyond our control. The alternative is to use Google (Advanced Search mode) and limit your search to www.voiceguide.com
