CSI Report post Posted 02/18/2009 02:24 PM I have several existing IVR scripts which utilize Allison (the default system voice) for custom prompts. I have a new program that must utilize a different voice talent. If I have the new voice talent record the system prompts that I need (numbers, dates, etc.), then how do I utilize the current system prompts for every other script and the second set of system prompts only for this one new script? I do not want to overwrite the old system prompts since they are actively used and I do not want to change the old scripts/prompts at all. Thank you for your help. Share this post Link to post
SupportTeam Report post Posted 02/18/2009 07:53 PM The system sound directory can be set dynamically from within the script by setting the $RV[DIRSYSTEMVOICE] Result Variable Please see: http://www.voiceguide.com/vghelp/source/ht...ti-language.htm Share this post Link to post
