Time (in Milliseconds) Tone Dtmf
Good Morning,
I need your help again, In this time I need to know the time (in milliseconds),that it takes, send a tone, from the application to the phone.
And after the first tone have been sent, how much time spent in send the second tone.
Can I modify these times? How can I modify it?
Thanks a lot for your support,
Best regards,
Are you talking about the DTMF tones that VoiceGuide can play?
Are you using VoiceGuide v7?
In VoiceGuide v7 the DTMF tone timings can be adjusted in the Config files.
The ConfiLine files:
<Parameter>
<Description>DTMF Interdigit delay (time between digits in DTMF dialing)</Description>
<Notes></Notes>
<Key>DXCH_T_IDD</Key>
<Value>5</Value>
<Default>5</Default>
</Parameter>
<Parameter>
<Description>DTMF length (duration) for dialing.</Description>
<Notes></Notes>
<Key>DXCH_TTDATA</Key>
<Value>10</Value>
<Default>10</Default>
</Parameter>
(5 ,10)
Are these values expressed in milliseconds or in another unit of time?
Both DXCH_T_IDD and DXCH_TTDATA are in units of 10ms. A setting of 5 represents 50ms
