mehdi_h Report post Posted 03/16/2009 08:47 PM Hi Im using a same script that asks the user to enter a Capture Number Module. When using outgoing calls the system reacts when pressing keys to enter the number : OK When using incoming script, the system does not react when pressing the keys to enter the number NOK any adea? Tkx MH Share this post Link to post
SupportTeam Report post Posted 03/16/2009 10:06 PM Are you saying that the keys pressed on the phone are not being detected? Have you tried using some other different phones to place the calls? Sometimes you get a phone which does not send the DTMF tones clearly so they tones are not detected reliably. Share this post Link to post
mehdi_h Report post Posted 03/17/2009 06:11 PM sorry in fact the ougoing and incoming calls where not done through the same line (I thought so) and it seems that on one line which is a line behind an internet box, incomming dtmf code are filtered and not transfered to te server. I 'll check that. sorry tkx Share this post Link to post
mehdi_h Report post Posted 03/17/2009 08:44 PM I have made some tests using this line and have recorded when pressing keys. I have indeed the dtmf signal recorded but not recognized by VG as pressed keys. Please find the recorded way. and the logs also. Thanks MH 0317212010_9_0619601838.wav 0317_1912_vgEngine.zip Share this post Link to post
SupportTeam Report post Posted 03/18/2009 12:18 AM The DTMF tones in the recording sound fine. Can that card detect DTMF tones when you try using it with some sample apps that are installed along with Dialogic drivers? Share this post Link to post
SupportTeam Report post Posted 03/18/2009 12:24 AM If that recording was for incoming call can you make the same recording on an outgoing call and press a few dtmf tones (all 12 would be good) while the recording is being made. The outgoing call should be made to the same phone that was used to dial in and make the previous recording. Then post traces (vgEngine and ktTel) and the recorded sound file again. Share this post Link to post
mehdi_h Report post Posted 03/20/2009 01:37 PM Hi here are my records. seems that the signal length is not correct Tkx Mh outgoing.wav incoming.wav Share this post Link to post
SupportTeam Report post Posted 03/20/2009 08:21 PM Could you post the the traces from VoiceGuide as well (.ZIPed) ? Especially the ktTel or the tw traces. Share this post Link to post
mehdi_h Report post Posted 03/20/2009 10:43 PM Hi Please find bell all the files . Wav files and logs. Tkx Mh log.zip Share this post Link to post
SupportTeam Report post Posted 03/20/2009 11:36 PM Traces show that no DTMF tones were detected/reported on either the incoming or the outgoing calls. Listening to the recorded sound files the keypreses sound short and distorted on both the incoming or the outgoing calls, and looking at the recordings in the sound editor confirms this. The problem here is either with the phone that is being used or there is some soft of impedance mismatch on the lines and/or the Dialogic card that distorts the sound on the line. Share this post Link to post
