Script Question
I was experienceing something and I wanted to have your confirmation that it may be the cause of my script trouble:
I was doing this basic test (following) , where GET_MAT_APR and GET_JOUR are two get number modules. When NOT putting "" to $RV[GET_JOUR] and $RV[GET_MAT_APR], the scripts does not work properly. It gets to the next module after a while. When putting "" everything seems to be OK. Do you confirm that NOT putting "" could have such effect on the script ?
thkx
GetJour=right("$RV[GET_JOUR]",2) & left("$RV[GET_JOUR]",2)
if "$RV[GET_MAT_APR]"="1" then
GetHour="10"
end if
if "$RV[GET_MAT_APR]"="2" then
GetHour="14"
end if
The $RV is a placeholder that will get substituted by the value assigned to the $RV before the script is ran.
In the case of:
you must put quotes around the $RVs
but in case of
it is not a must, but is strongly advised, as otherwise if you used:
if $RV[GET_MAT_APR]=1 then
and nothing was entered in the GET_MAT_APR module then the VBScript would become:
if =1 then
which is a syntax error.
