Use Db Query Module To Create A File
I would like to have a DB Query Module to either create an outdial.xml file that I can copy to the data directory to place calls or have the db query module populate the callque table directly.
How have others done this the most effeciently?
Using the outdial.xml file is an easier option. The outdial.xml file is best created from a Run VBScript module.
To write entries directly to the OutDial database you would need to use the The DB Query module (can alos be done from a VBScript module is you want to write the VBScript to open DB connections and make the updates).
