Incoming Calls
How can I diseable the incomings calls to be picked up by VG when a call is arriving the on of the lines?
Tkx
Mh
You can set the number of "rings before answer" on that line to be a high number. eg: 100
This will result in no calls will be answered on that line.
Anotehr approach is to setup a script to "Start before Answering call" and just use a hangup module in that script. VoiceGuide will then not pickup the handset (ie. won't answer the call).
See: http://www.voiceguide.com/vghelp/source/ht...all%20start.htm
