Guest ayman Report post Posted 03/31/2009 01:13 PM hello every body i want to use VG as sip client for my nortel PBX you provide the next link for example http://www.voiceguide.com/vghelp/source/ht...ip_register.htm but it does not contain nortel the question is do you support nortel as a voip gateway? how i could make this integration? regards ayman Share this post Link to post
SupportTeam Report post Posted 03/31/2009 08:18 PM Yes. All SIP PBXs are supported. H.323 is supported as well. The Help file just gives a series of examples, and you can see that in all cases the configuration is all pretty much the same. Sometimes people have problems placing the right information in the right places in the configuration file, and if you have any issues in getting it working just post your current Config.xml file along with PBX and extension etc details here and we can modify the Config.xml for you to get you working. Share this post Link to post
