Outdialer: Designated Line Restriction Not Working
On our Outdialer v7.0.2967.33853, we are designating line 1 in the area labeled 'Dial on these lines only:', yet the dialer is attempting to make calls on line 2. We are using a 4 port Dialogic D/4PCI UF card with only one analog telephone line connected.
Please attach the traces capturing the call being loaded and the call then being made.
These are all the log files, cdr, and response files where we designated line 1 only. Watching the line status, I could see it dialing and playing wav files on line 3. None of these files are showing the campaign name.
vglinetest.zip
Trace shows that you are using the XML file to load new calls, not the Telephone Number Loader:
144803.690 20 0 OutDial load from [C:\Program Files\VoiceGuide\data\OutDial_New.xml]
In the XML file ensure you have these entries:
<LineSelection>1</LineSelection>
<PortSelection>1</PortSelection>
in the newer versions of VoiceGudie v7 the PortSelection field is used, the LineSelection field was used by older versions.
