Need Help! Outbound Calls Being Repeated.
Hi. I started a campaign with 6,077 calls on the 15th. I had them in an xml file and copied the file to the data directory. I noticed VG was really slow to load them and dial, so I took out the "priority sort" in the config.xml. Then I restarted VG. It took a few minutes but started dialing. It did calls all day on the 15th. now on the 16th it started calls again (4 lines) and I thought it would be about finished. I noticed that some calls were being made twice or more on each number. So I looked in the call que and there are still over 5,427 calls remaining in here (VG default database).
So, I looked in the cdr out file, and there are 3,457 records in the CDR out on the 16th and 2,725 in the CDR out file on the 15h.
So what is going on here? Are the calls not being deleted properly out of the call que as they are being made? How can I reconcile what has already been called and limit the call que (or delete records to not call people multiple times)? Some got as many as 6 calls!
I attached the latest log.
Thanks, this is time sensitive!
0416_1912_vgEngine.zip
Can you give us an example phone number that was called multiple times and we can then look in the trace to see what happened on calls to that number.
I think you should have a look at the CDR logs to see what was the outcome of the calls. In the log that you have provided there is a large number of reports of Tri-Tones (Operator Intercept Special Information Tones) being played. In which case the call will be aborted as it looks like the phone company will not connect an outgoing call right now. In SIT cases VoiceGuide will dial the number at a later time.
You will need to resolve why the phone company is playing the operator tone (SIT Tones) when VoiceGuide attempts to make a call on these lines.
The SIT calls I'm not worried about at this point. I can work on that later. I see that calls were made on the 14th and repeated again on the 15th. Also it looks like the callque table is not purging it's records properly. Can it not handle 6,000 calls?
bl2.zip
The CDR extract attached shows 10 numbers being dialed on 2009-04-15 19:20-19:35, and then the same 10 numbers being called on 2009-04-16 16:50-16:55.
We would need to see the vgEngine traces from those times to see whether the same call entries were dialed twice or the calls were just loaded twice into the system.
6000 calls is a easily handled, even by the default database engine that ships with VoiceGuide. Once you get to loading 50,000-100,000+ calls into system you may want tolook at using MySQL or SQLServer etc. instead, but at 6000 calls level the retrieval speed is fine from the standard database engine.
Here is the CDR extract that was attached to the previous post:
purpose,phone,Field3,Field4,Field5,Field6,Field7,script,Field9,starttime,Field11
,endtime,lencall,Field14,disp,Field16
Business License,912012694369,,,,0,,e:\payrem\buslic_renew.wav,,2009-04-16 16:52:21,NULL,2009-04-16 16:53:40,79,0,ANSWERED_MACHINE,
Business License,912012694369,,,,0,,e:\payrem\buslic_renew.wav,,2009-04-15 19:21:26,NULL,2009-04-15 19:22:45,79,0,ANSWERED_MACHINE,
Business License,912013520559,,,,0,,e:\payrem\buslic_renew.wav,,2009-04-16 16:52:43,NULL,2009-04-16 16:53:50,67,0,ANSWERED_MACHINE,
Business License,912013520559,,,,0,,e:\payrem\buslic_renew.wav,,2009-04-15 19:21:51,NULL,2009-04-15 19:22:58,67,0,ANSWERED_MACHINE,
Business License,912013974259,,,,0,,e:\payrem\buslic_renew.wav,,2009-04-16 16:53:30,NULL,2009-04-16 16:54:42,72,0,ANSWERED,
Business License,912013974259,,,,0,,e:\payrem\buslic_renew.wav,,2009-04-15 19:21:51,NULL,2009-04-15 19:23:03,72,0,ANSWERED,
Business License,912017396024,,,,0,,e:\payrem\buslic_renew.wav,,2009-04-16 16:53:34,NULL,2009-04-16 16:54:11,36,0,ANSWERED_HUMAN,
Business License,912017396024,,,,0,,e:\payrem\buslic_renew.wav,,2009-04-15 19:22:50,NULL,2009-04-15 19:23:56,66,0,ANSWERED_MACHINE,
Business License,912034865678,,,,0,,e:\payrem\buslic_renew.wav,,2009-04-16 16:53:44,NULL,2009-04-16 16:55:03,80,0,ANSWERED_MACHINE,
Business License,912034865678,,,,0,,e:\payrem\buslic_renew.wav,,2009-04-15 19:23:02,NULL,2009-04-15 19:24:20,78,0,ANSWERED_MACHINE,
Business License,912037686475,,,,0,,e:\payrem\buslic_renew.wav,,2009-04-16 16:53:53,NULL,2009-04-16 16:54:24,31,0,ANSWERED_HUMAN,
Business License,912037686475,,,,0,,e:\payrem\buslic_renew.wav,,2009-04-15 19:23:06,NULL,2009-04-15 19:24:02,55,0,ANSWERED_HUMAN,
Business License,912038650811,,,,0,,e:\payrem\buslic_renew.wav,,2009-04-16 16:54:25,NULL,2009-04-16 16:54:53,28,0,ANSWERED_MACHINE,
Business License,912038650811,,,,0,,e:\payrem\buslic_renew.wav,,2009-04-15 19:24:00,NULL,2009-04-15 19:24:54,55,0,ANSWERED_MACHINE,
Business License,912038823700,,,,0,,e:\payrem\buslic_renew.wav,,2009-04-16 16:54:28,NULL,2009-04-16 16:55:16,49,0,ANSWERED_MACHINE,
Business License,912038823700,,,,0,,e:\payrem\buslic_renew.wav,,2009-04-15 19:24:05,NULL,2009-04-15 19:24:54,49,0,ANSWERED_MACHINE,
Business License,912053914848,,,,0,,e:\payrem\buslic_renew.wav,,2009-04-16 16:54:46,NULL,2009-04-16 16:55:09,23,0,ANSWERED_HUMAN,
Business License,912053914848,,,,0,,e:\payrem\buslic_renew.wav,,2009-04-15 19:24:24,NULL,2009-04-15 19:25:53,89,0,ANSWERED_MACHINE,
Business License,912055929673,,,,0,,e:\payrem\buslic_renew.wav,,2009-04-16 16:54:57,NULL,2009-04-16 16:55:46,49,0,ANSWERED_HUMAN,
Business License,912055929673,,,,0,,e:\payrem\buslic_renew.wav,,2009-04-16 08:58:52,NULL,2009-04-16 08:59:38,46,0,ANSWERED_HUMAN,
The attached trace goes from 08:24:20 till 09:59:15. This does not cover any of the times mentioned before.
What are we supposed to be looking at in this trace?
Attached is a file from the 16th. Look about this time. There is an entry that is close to an example.
165353.003 6 5 rv add [$RV_STARTTIME]{2009-04-16 16:53:53}
So above, this number was called twice. I'll attach the log with the other date as well.
0416_1528_vgEngine.zip
The 0416_1528_vgEngine.zip trace does not go till 19:23, so its not possible to see the second call to 912017396024. Pleae .ZIP up and post the trace that covers the 19:23 time on the 16th April and we can then see why the call at 19:22:50 was made.
What calls are we supposed to be looking at in the 0415_1756_vgEngine.zip trace?
165334.597 10 dial DbProcessQueue_Callback_DoWorkFindCall objDbDataReader_Stage2.Read() returned True
165334.597 10 dial DbProcessQueue_Callback_DoWorkFindCall objDbDataReader_Stage2.iFieldCount=18, sTaskTimestamp=165334.487, diff=00:00:00.1093743
165334.597 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.iID=5288
165334.597 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.guid=9333f2a7-a067-4ed5-98fb-575e47ed9252
165334.597 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.strPhoneNumber=[2017396024]
165334.597 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.strPhoneNumberPrefix=[91]
165334.597 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.datetimeActivation=[4/14/2009 3:54:45 PM]
165334.597 10 dial live=e:\payrem\buslic_renew.wav, am=e:\payrem\buslic_renew.wav, fax=, onNotAnswer=, onRetriesExhausted=
165334.597 10 dial iRetriesDelay_Seconds=300
165334.597 10 dial callque update id/guid=5288/9333f2a7-a067-4ed5-98fb-575e47ed9252 nextActivateTime=4/16/2009 4:58:34 PM, retriesLeft=1, iRelatedPortNumber=3 : completed ok
165334.597 10 dial FindCallQueryCompleted a call was found. Port= 3, sTaskTimestamp=165334.487, diff=00:00:00.1093743
165334.597 10 5 dial StartOutgoingCall start tel[2017396024] live[e:\payrem\buslic_renew.wav] am[e:\payrem\buslic_renew.wav] fax[] onNotAnswered[] onRetriesEnd[] rv[] CampaignName[business License] options[] ID=5288
165334.597 10 5 LineState set Dialing
165334.597 10 5 dial making call LineState settings: tel[912017396024] live[e:\payrem\buslic_renew.wav] am[e:\payrem\buslic_renew.wav] fax[] noAnswer[] retriesEnd[] OnHangup[] rv[[OutDial_RetriesLeft]{2}] options=[]
165334.597 10 5 answering machine detection enabled. sCallProgressOption = [DX_PAMDOPTEN]
165353.003 17 5 ev Dialogic 133,TDX_CALLP, crn=200009dd, 10,3,0,TDX_CALLP,CR_CNCT,CON_PVD
165353.003 6 5 Set_hCall crn=200009dd, called from OnOutboundCallAnswered_Start_HumanAnswer_Option
165353.003 6 5 dial DeleteFromOutDialQue ID=5288
165353.003 6 5 state Human answer. Playing e:\payrem\buslic_renew.wav
165353.003 10 dial Db_Delete_Entry begin id=5288 guid=9333f2a7-a067-4ed5-98fb-575e47ed9252 linkField=GUID, sql=[DELETE FROM CallQue WHERE ID=@iID; DELETE FROM PortToUse WHERE CallID=@iID;DELETE FROM CallQue WHERE GUID=@guid; DELETE FROM PortToUse WHERE CallGUID=@guid;]
165353.003 10 dial Db_Delete_Entry end id=5288 guid=9333f2a7-a067-4ed5-98fb-575e47ed9252
165409.972 17 5 ev Dialogic 134,TDX_CST, crn=200009dd, 1697,0,0,DE_LCOF,,
165411.097 6 5 writing CDR logs
165411.097 6 5 cdr.sDisposition=ANSWERED_HUMAN
165411.097 6 5 NOTE strDialoutTelNbr=912017396024, strCallerIdNbr=
165411.097 6 5 VG.INI/Log/CDR_LastData_SaveRv=0 - RVs XML will NOT be saved in LastApplicationData CDR field.
165411.097 6 5 CDR (out) : "Business License","912017396024","","","","0","","e:\payrem\buslic_renew.wav","","2009-04-16 16:53:34","NULL","2009-04-16 16:54:11",36,0,"ANSWERED_HUMAN",""
165411.097 6 5 CDR SQL: INSERT INTO CdrOut (Account, Src, Dst, Dcontext, Clid, Channel, Dstchannel, Lastapp, Lastdata, Start, Answer, Hangup, Duration, Billsec, Disposition, Amaflags) VALUES ('Business License','912017396024','','','','0','','e:\payrem\buslic_renew.wav','','2009-04-16 16:53:34',NULL,'2009-04-16 16:54:11',36,0,'ANSWERED_HUMAN','')
Take a look at this phone numbe: 3144238000
It was called on the 15th and 16th. Both were "Answering Machine".
So the question is why it didn't delete it from the callque and call twice?
0415_1756
Phone number: 3144238000
"Business License","913144238000","","","","0","","e:\payrem\buslic_renew.wav","","2009-04-15 19:41:22","NULL","2009-04-15 19:42:45",83,0,"ANSWERED_MACHINE",""
ScriptEvent EV_TIMEOUT_AFTERIDLE_ALLOWOUT ||
194122.066 6 3 LineState set Null
194122.160 10 dial FindCallQueryCompleted some calls found (any lineid search), ID/GUID=-1/f8e24545-ce14-4fa9-b1c0-fc3400f44de5, sTaskTimestamp=194122.082, diff=00:00:00.0781245
194122.160 10 dial port 1 : LineStateAppPov=Connected
194122.332 10 dial DbProcessQueue_Callback_DoWorkFindCall objDbDataReader_Stage2.Read() returned True
194122.332 10 dial DbProcessQueue_Callback_DoWorkFindCall objDbDataReader_Stage2.iFieldCount=18, sTaskTimestamp=194122.160, diff=00:00:00.1718739
194122.332 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.iID=3457
194122.332 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.guid=f8e24545-ce14-4fa9-b1c0-fc3400f44de5
194122.332 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.strPhoneNumber=[3144238000]
194122.332 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.strPhoneNumberPrefix=[91]
194122.332 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.datetimeActivation=[4/14/2009 3:53:18 PM]
194122.332 10 dial live=e:\payrem\buslic_renew.wav, am=e:\payrem\buslic_renew.wav, fax=, onNotAnswer=, onRetriesExhausted=
194122.332 10 dial iRetriesDelay_Seconds=300
194122.332 10 dial callque update id/guid=3457/f8e24545-ce14-4fa9-b1c0-fc3400f44de5 nextActivateTime=4/15/2009 7:46:22 PM, retriesLeft=1, iRelatedPortNumber=2 : completed ok
194122.332 10 dial FindCallQueryCompleted a call was found. Port= 2, sTaskTimestamp=194122.160, diff=00:00:00.1718739
194122.332 10 3 dial StartOutgoingCall start tel[3144238000] live[e:\payrem\buslic_renew.wav] am[e:\payrem\buslic_renew.wav] fax[] onNotAnswered[] onRetriesEnd[] rv[] CampaignName[business License] options[] ID=3457
194122.332 10 3 LineState set Dialing
194122.332 10 3 dial making call LineState settings: tel[913144238000] live[e:\payrem\buslic_renew.wav] am[e:\payrem\buslic_renew.wav] fax[
0416_1528
"Business License","913144238000","","","","0","","e:\payrem\buslic_renew.wav","","2009-04-16 17:06:46","NULL","2009-04-16 17:08:09",83,0,"ANSWERED_MACHINE",""
7 ScriptEvent EV_TIMEOUT_AFTERIDLE_ALLOWOUT ||
170646.639 6 7 LineState set Null
170646.639 10 dial FindCallQueryCompleted some calls found (any lineid search), ID/GUID=-1/59e88a0c-2684-427c-9653-57993730400b, sTaskTimestamp=170646.592, diff=00:00:00.0468747
170646.639 10 dial port 1 : LineStateAppPov=Dialing
170646.639 10 dial port 2 : LineStateAppPov=Connected
170646.639 10 dial port 3 : LineStateAppPov=Connected
170646.748 10 dial DbProcessQueue_Callback_DoWorkFindCall objDbDataReader_Stage2.Read() returned True
170646.748 10 dial DbProcessQueue_Callback_DoWorkFindCall objDbDataReader_Stage2.iFieldCount=18, sTaskTimestamp=170646.639, diff=00:00:00.1093743
170646.748 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.iID=5343
170646.748 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.guid=59e88a0c-2684-427c-9653-57993730400b
170646.748 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.strPhoneNumber=[3144238000]
170646.748 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.strPhoneNumberPrefix=[91]
170646.748 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.datetimeActivation=[4/14/2009 3:54:48 PM]
170646.748 10 dial live=e:\payrem\buslic_renew.wav, am=e:\payrem\buslic_renew.wav, fax=, onNotAnswer=, onRetriesExhausted=
170646.748 10 dial iRetriesDelay_Seconds=300
170646.764 10 dial callque update id/guid=5343/59e88a0c-2684-427c-9653-57993730400b nextActivateTime=4/16/2009 5:11:46 PM, retriesLeft=1, iRelatedPortNumber=4 : completed ok
170646.764 10 dial FindCallQueryCompleted a call was found. Port= 4, sTaskTimestamp=170646.639, diff=00:00:00.1249992
170646.764 10 7 dial StartOutgoingCall start tel[3144238000] live[e:\payrem\buslic_renew.wav] am[e:\payrem\buslic_renew.wav] fax[] onNotAnswered[] onRetriesEnd[] rv[] CampaignName[business License] options[] ID=5343
170646.764 10 7 LineState set Dialing
170646.764 10 7 dial making call LineState settings: tel[913144238000] live[e:\payrem\buslic_renew.wav] am[e:\payrem\buslic_renew.wav] fax[] noAnswer[] retriesEnd[] OnHangup[] rv[[OutDial_RetriesLeft]{2}] options=[]
170646.764 10 7 answering machine detection enabled. sCallProgressOption = [DX_PAMDOPTEN]
170646.764 10 7 rv clear all
170646.764 10 7 rv add [OutDial_RetriesLeft]{2}
170646.764 10 7 state Dialing 913144238000
170646.764 10 7 t set 60 sec : EV_TIMEOUT_MAKECALL_NORESPONSE
170646.764 10 7 rvns add [OutDial_Result]{NOTCONTACTED}
170646.764 10 7 rvns add [OutDial_Result]{NOANSWER}
170646.764 10 7 ktTel_MakeCall_Enqueue([913144238000],DX_PAMDOPTEN, 60,0,0,,) call
170646.764 10 7 tqTel que cmd_MakeCall [0,0,60,0,0][||913144238000|DX_PAMDOPTEN|]
170646.764 7 7 tqTel run cmd_MakeCall
170646.764 7 7 ev generic: ktTel_Completion 10000 0,Completion_MakeCall, crn=20000a21, 536873505,0,0,913144238000,,<result>ok</result><crn>536873505</crn>
170646.764 7 7 qScr add evktTelCompletion 0 Completion_MakeCall
170646.764 6 7 qScr run evktTelCompletion Completion_MakeCall, iActionID=0, crn=0[536873505|0|0|0|0][913144238000||<result>ok</result><crn>536873505</crn>|||]
170646.764 6 7 OnCompletion_ktTel_MakeCall sRet=[<result>ok</result><crn>536873505</crn>]
170646.764 6 7 LineState set Dialing
170646.764 6 7 ScriptState set , (called from OnCompletion_ktTel_MakeCall)
170646.764 6 7 state Dialing 913144238000...
170647.326 17 7 ev Dialogic 135,TDX_SETHOOK, crn=20000a21, 0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
170647.326 17 7 qScr add evScriptEvent 135 TDX_SETHOOK
170647.326 6 7 qScr run evScriptEvent TDX_SETHOOK, iActionID=0, crn=20000a21[0|0|0|0|0][DX_OFFHOOK|CALL_OUTBOUND||||]
The number was loaded into the database twice.
At the time the calls are loaded into the database the database assigns the unique ID to each row in the CallQue table. At the time rows are retrieved VoiceGuide reports the ID (and the GUID as well).
We can see:
first call:
second call:
OK. I didn't think so, but I was wondering the same thing after looking at some of the ID's. I'll do some testing from this end.
I thought I loaded it one time (copying the xml to the data directory), so I'll check that.
Also the initial activation time is set to the time the call was loaded, so we can see that first call was loaded at 4/14/2009 3:53:18 PM, and the second call was loaded at 4/14/2009 3:54:48 PM
