Breakout Scripts
Im currently adding to our scripts with new stuff our old scripts were huge so I've decided to stick them into different script sections each to do a specific task etc.
I have a main script that holds the main options and processs for the IVR call. From specific modules I call scripts using VBScript as below
vg.Script_Gosub $RV_LINEID, "EngineerCompletion_Engineer_Pin.vgs", "", "", "", ""
set vg = Nothing
This works fine and the script variables are usable between the master and child scripts. The problem I have is returning to the calling script I have used
vg.Script_Return $RV_LINEID, "success"
vg.Run_ResultReturn $RV_LINEID, ""
set vg = Nothing
But the call just gets terminated with nothing in the log as far as I can see to say why. The VBScript calling the child script has a success goto but nothing happens. What am I doing wrong?
Many thanks
Andy
