mehdi_h Report post Posted 04/24/2009 05:01 PM hi Team, In my system during outgoing calls, I have a *.wav file that has been played "teamcell.wav", the problem is that I can't understand why this file is played. Could you please have a look on the logs to know why this file is applied in which script. Thank you Mh 0424_1811_vgEngine.zip Share this post Link to post
SupportTeam Report post Posted 04/24/2009 10:11 PM Trace shows that TeamCell.wav is played from script test.vgs, module [M1]. 183933.484 10 dial FindCallQueryCompleted some calls found (any lineid search), ID/GUID=9032/00000000-0000-0000-0000-000000000000, sTaskTimestamp=183933.390, diff=00:00:00.0937500 183933.531 10 dial DbProcessQueue_Callback_DoWorkFindCall objDbDataReader_Stage2.Read() returned True 183933.531 10 dial DbProcessQueue_Callback_DoWorkFindCall objDbDataReader_Stage2.iFieldCount=18, sTaskTimestamp=183933.484, diff=00:00:00.0468750 183933.531 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.iID=10613 183933.531 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.guid is not used LinkField=[iD] 183933.531 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.strPhoneNumber=[0686360199] 183933.531 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.strPhoneNumberPrefix=[0] 183933.531 10 dial DbProcessQueue_Callback_DoWorkFindCall oOutCallData.datetimeActivation=[24/04/2009 18:17:37] 183933.531 10 dial DbProcessQueue_Callback_DoWorkFindCall error retrieveing strCallOptions. (probably set to null string) 183933.531 10 dial DbProcessQueue_Callback_DoWorkFindCall error retrieveing strEscalationCalls. (probably set to null string) 183933.531 10 dial live=C:\Program Files\VoiceGuide\Scripts\test.vgs, am=, fax=, onNotAnswer=, onRetriesExhausted= 183933.531 10 dial iRetriesDelay_Seconds=10800 183933.656 10 dial callque update id/guid=10613/00000000-0000-0000-0000-000000000000 nextActivateTime=24/04/2009 21:39:33, retriesLeft=-1, iRelatedPortNumber=1 : completed ok 183933.656 10 dial FindCallQueryCompleted a call was found. Port= 1, sTaskTimestamp=183933.484, diff=00:00:00.1718750 183933.656 10 1 dial StartOutgoingCall start tel[0686360199] live[C:\Program Files\VoiceGuide\Scripts\test.vgs] am[] fax[] onNotAnswered[] onRetriesEnd[] rv[[clientid]{}] CampaignName[TEST CLIENT] options[] ID=10613 ... 184005.562 6 1 state Human answer. Start [C:\Program Files\VoiceGuide\Scripts\test.vgs] ... 184005.562 6 1 StartModuleDefault=[M1] ... 184005.562 6 1 state [M1] Playing wav (C:\Program Files\VoiceGuide\Sound\TeamCell.wav) Share this post Link to post
