Answer Timeout Is Not Working
The timeout value was correctly read in form the input file and set on the outbound call. This line from the ktTel trace shows this:
115953.750 924 1 fn LineMakeCall(iLineId=1, iCallRequestId=0 (ignored), strNumberToCall=[18310756677522], callprog=DX_PAMDOPTEN, timeout=45, params:0,0,cid=[(null)],opt=[])
Trace shows that the analog Dialogic card whic you are using reported hearing a Busy tone on the line about 11 seconds after the number was dialed. You would see a "BUSY" call result in the CDR log:
"zen monk","18310756677522","","","","0","","","","2009-04-29 11:59:53","NULL","2009-04-29 12:00:04",11,0,"BUSY",""
When using analog cards you need to define the tones that the analog card will listen for and react to. On analog lines the tones played on the line tell the card what is happening on the line. The default tone definitions work OK with most Telcos, but in your case it looks like the ringback tone may be mistaken for a busy tone.
Please see this help file page for information on how the tone detection setting are set: http://www.voiceguide.com/vghelp/source/ht...ctiondetect.htm
ktTel trace shows your current Busy tone defintions are:
115940.406 924 tone ch id:TID_BUSY1:253, f1:500:200, f2:0:0, cad:55:40,55:40, count:4
115940.406 924 tone ch id:TID_BUSY2:255, f1:500:200, f2:525:175, cad:55:40,55:40, count:4
