Could Not Get Caller Id
I have DMV480A-2T1 board. I could not get the caller ID from it.
I tried in the PSTNDiag, and it does not show up the caller ID either. So I think it must be the phone company does not pass down the caller ID. But I called Verizon, they said they did. :(..
So, I tried to log a call with ISDNTRACE and see if the caller number is in it. I don't see it.
I attached the log file here. Can you take a look for me? Thanks.
I don't know where or which section the caller number should be though. Here is the piece that has the CALL PROCEEDING.
Thu Apr 30 18:16:10 2009
RX Frame: Time = 389.996
Command=1 SAPI=0x00
TEI=0x00
0x74 0x8e Information
PD=0x08 Dest=0 CR=0x0015
SETUP(0x05)
1: BEARER CAPABILITY(0x04)
2: IE Length(0x03)
3: 1------- Extension Bit
-00----- Coding Standard
---00000 Info. Transfer Cap.
4: 1------- Extension Bit
-00----- Transfer Mode
---10000 Info. Transfer Rate
5: 1------- Extension Bit
-01----- Layer 1 Indent
---00010 User Info. Layer 1
1: CHANNEL ID(0x18)
2: IE Length(0x03)
-0------ Interface ID Present
--1----- Interface Type
---0---- Spare
----0--- Preferred/Exclusive
-----0-- D-Channel Indicator
------01 Info. Channel Sel.
3.2: 1------- Extension Bit
---0---- Number Map
----0011 Channel/Map Element
-0000001 Channel Number/Slot Map
1: NETWORK SPEC. FAC.(0x20)
2: IE Length(0x02)
3: 0x00 Length Of Network ID
1------- Parameterized/Binary
-1------ Expansion Bit
--1----- Feature/Service
---00010 MEGACOM 800
1: CALLED PARTY NUM(0x70)
2: IE Length(0x0b)
-010---- Type of Number
----0001 Numbering plan ID
8662837255 Number Digit(s) --> this is called number, not caller number.
Hex Dump:
02 01 74 8e 08 02 00 15 05 04
03 80 90 a2 18 03 a1 83 81 20
02 00 e2 70 0b a1 38 36 36 32
38 33 37 32 35 36
TX Frame: Time = 390.0
Command=1 SAPI=0x00
TEI=0x00
0x01 0x76 Receive Ready
Hex Dump:
02 01 01 76
Thu Apr 30 18:16:12 2009
TX Frame: Time = 391.900
Response=0 SAPI=0x00
TEI=0x00
0x8e 0x76 Information
PD=0x08 Orig=1 CR=0x8015
CALL PROCEEDING(0x02)
1: CHANNEL ID(0x18)
2: IE Length(0x04)
-1------ Interface ID Present
---0---- Spare
----1--- Preferred/Exclusive
3.1: 1------- Extension Bit
-0000000 Interface Identifier
---0---- Number Map
Hex Dump:
00 01 8e 76 08 02 80 15 02 18
04 e9 80 83 81
RX Frame: Time = 391.912
TEI=0x00
0x01 0x90 Receive Ready
Hex Dump:
00 01 01 90
TX Frame: Time = 392.0
TEI=0x00
0x90 0x76 Information
CALL CONNECT(0x07)
Hex Dump:
00 01 90 76 08 02 80 15 07
RX Frame: Time = 392.12
TEI=0x00
0x01 0x92 Receive Ready
Hex Dump:
00 01 01 92
RX Frame: Time = 392.16
Command=1 SAPI=0x00
TEI=0x00
0x76 0x92 Information
CALL CONNECT ACKNOWLEDGE(0x0f)
Hex Dump:
02 01 76 92 08 02 00 15 0f
test_04302009_18h15m42s.log
Trace shows no CallerID sent.
Have you show the trace to your Telco?
Telco should be able to quickly make their own ISDN traces on the line as well to confirm this as well.
