Sytem Error When I Try To "set And Run Current Script"
Hello,
I get a systems error when I try to "Set and Run current script" ... I've simplified it to the bone. Any suggestions ?? Running XP with Dialogic drivers. This is the only thing running on this machine, so if we need to strip it down and rebuild thata ok ...
Thank you,
Dave R.
Sounds like you are not using version 7 of VoiceGuide. Which version are you using?
Which Dialogic card are you using?
I am using version 6 of Voiceguide. The dialogic card is a D/41EPCI.
Thanks,
Dave R.
The "Set and Run current script" option does not work in v6. You need to set the script to be used by each line using the Config.xml file.
