jewillis Report post Posted 05/19/2009 08:42 PM Are the below column names (GUID/CallGUID) correct? The VG DB script creates these names, BUT if we use the linkfield, shouldn't the column names be the same in both tables. I have had issues where data from the tables are not in sync and the only thing I can assume is because the column names are different and the linkfield will not see them correctly Jeff CREATE TABLE CallQue ( ID Int IDENTITY(1, 1) PRIMARY KEY, GUID UniqueIdentifier, CREATE TABLE PortToUse ( CallID Int, CallGUID UniqueIdentifier, <OutDialQue_PortToUse_LinkField>GUID</OutDialQue_PortToUse_LinkField> Share this post Link to post
SupportTeam Report post Posted 05/19/2009 09:57 PM The column names as quoted are correct. The CallGUID column stores the GUID from the referenced entry in the CallQue table. The OutDialQue_PortToUse_LinkField config field does not actually specify the column name, it specifies the general approach/algorithms to use. Share this post Link to post
