Problem Sending Fax
What is wrong?
I have using a xml file to call a vg script and send a pdf file.
The script is not working...
I have upload the script, xml and log. The vg script could load the script!
What I'm doing wrong?
vg_fax.zip
This issue does not appear to exist when tested for in the current latest v7 release.
Please update system to latest v7 version and you should be able to use a vgs/vgp script for the fax entry.
I understand that you are currently able to send faxes ok when specifying pdf/tif/tiff in the fax entry. yes?
154620.635 3 3 sending fax on outgoing call.
154620.635 3 3 OnOutboundCallAnswered_Start_SendFax_Option 0,0,0
154620.635 3 3 Set_hCall crn=20000002, called from StartSendingFaxMessage
154620.635 3 3 NewVgsVgm_Goto C:\ProjectsVgNet\bin\Scripts\Credit Card Payment\Credit Card Payment.vgs,,,,,0
154620.635 3 3 NewVgsVgm_Goto_Setup dest=C:\ProjectsVgNet\bin\Scripts\Credit Card Payment\Credit Card Payment.vgs|, return=|, lSaveSourceOnCallStack=0
154620.635 3 3 rv add [scriptEnd_Time]{2009-05-27 15:46:20}
154620.635 3 3 rv add [scriptEnd_Goto_Script]{C:\ProjectsVgNet\bin\Scripts\Credit Card Payment\Credit Card Payment.vgs}
154620.635 3 3 rv add [scriptEnd_Goto_Module]{}
154620.635 3 3 WriteToLogFiles_CurrScriptOnly begin
154620.635 3 3 WriteToLogFiles_CurrScriptOnly : LineState.iVgsIdx<=0
154620.635 3 3 rv add [scriptStart_Time]{2009-05-27 15:46:20}
154620.635 3 3 FindFullPathToScript_VgsOrVgp start [C:\ProjectsVgNet\bin\Scripts\Credit Card Payment\Credit Card Payment.vgs]
154620.635 3 LoadedVgs_Find C:\ProjectsVgNet\bin\Scripts\Credit Card Payment\Credit Card Payment.vgs at idx=2
154620.635 3 3 rvns add [scriptsPath]{C:\ProjectsVgNet\bin\Scripts\Credit Card Payment\}
154620.635 3 3 StartModuleDefault=[ModuleF]
154620.635 3 3 t timer clear (force=False)
154620.635 3 3 RunModule start [Play,[ModuleF],22]
154620.635 3 3 [ModuleF] VGMTYPE_PLAY run start
Hi Have upgraded to the vg 7.0 patch and re-ran the same xml.
Only this time the record was loaded into the db version and is not dialing. It just sitting there!
See log file for 9677 fax number.
And yes we can successful send pdf faxes using the vg outbound number loader.
Can you what going wrong?
0528_ktTts.zip
Trace shows the number being loaded:
091806.593 21 0 OutDial load from [C:\Program Files\VoiceGuide\data\OutDial_28520099186.xml]
091806.593 21 DialListLoadFileXML ReadAllText call
091806.593 21 0 Db_Insert_PrepareCmdParams AddParamToCmd calls
091806.593 21 0 Db_Insert_PrepareCmdParams cmdCQ.Parameters[...] set calls.
091806.593 21 0 dial Db_Insert_CallQueAndPortList CallQue insert call [18310755279677]
091806.593 21 0 dial cmd_CallQue_Insert.ExecuteReader [18310755279677] call
091806.703 21 0 dial cmd_CallQue_Insert.ExecuteReader [18310755279677] returned, some data FieldCount=1
091806.703 21 0 dial dr[iD] : Could not find specified column in results
091806.703 21 0 dial cmd_CallQue_Insert.ExecuteReader [18310755279677] sID=NOT SET, oID=2, iID=2
091806.703 21 0 dial Db_Insert_CallQueAndPortList CallQue insert returned TimeSpan=00:00:00.1093750
091806.703 21 dial Db_Insert_CallQueAndPortList iID_JustInserted=2
091806.703 21 dial Db_Insert_PortToUse id=2, guid=[89973cdf-5b43-45b5-9054-8a72e73dd447] sPortList=[3,4,5,6,7,8]
091807.156 21 dial Db_Insert_PortToUse inserts made: 6, ts=00:00:00.4531250
091807.156 21 dial Db_Insert_CallQueAndPortList Db_Insert_PortToUse returned
091807.156 21 0 OutDial input file : loaded 1 entries from C:\Program Files\VoiceGuide\data\OutDial_28520099186.xml
091807.156 21 OutDial input file deleted : C:\Program Files\VoiceGuide\data\OutDial_28520099186.xml
and immediately the call was found by the dialer:
091807.156 10 dial FindCallQueryCompleted some calls found (any lineid search), ID/GUID=2/00000000-0000-0000-0000-000000000000, sTaskTimestamp=091807.156, diff=00:00:00
091807.156 10 dial state 1:Null,2:Null,3:Null,4:Null,5:Null,6:Null,7:Null,8:Null,
091807.156 10 dial FindCallQueryCompleted a call was not found. Port= 1, sTaskTimestamp=091807.156, diff=00:00:00
091807.156 10 dial FindCallQueryCompleted a call was not found. Port= 2, sTaskTimestamp=091807.156, diff=00:00:00
091807.156 10 dial db do findcall objDbDataReader_Stage2.Read() returned True
091807.156 10 dial db do findcall objDbDataReader_Stage2.iFieldCount=18, sTaskTimestamp=091807.156, diff=00:00:00
091807.156 10 dial db do findcall oOutCallData.iID=2
091807.156 10 dial db do findcall oOutCallData.guid is not used LinkField=[iD]
091807.156 10 dial db do findcall oOutCallData.strPhoneNumber=[18310755279677]
091807.156 10 dial db do findcall oOutCallData.strPhoneNumberPrefix=[]
091807.156 10 dial db do findcall oOutCallData.datetimeActivation=[28/05/2009 9:17:00 AM]
091807.156 10 dial db do findcall oOutCallData.iRetriesCount/Delay(min)=[2/30]
091807.156 10 dial live=, am=, fax=C:\mediasol\customer_files\vg_fax\vg-fax.vgp, onNotAnswer=, onRetriesExhausted=
091807.265 10 dial callque update id/guid=2/00000000-0000-0000-0000-000000000000 nextActivateTime=28/05/2009 9:48:07 AM, retriesLeft=1, iRelatedPortNumber=3 : completed ok
091807.265 10 dial FindCallQueryCompleted a call was found. Port= 3, sTaskTimestamp=091807.156, diff=00:00:00.1093750
091807.265 10 0 qScr add cmdOutboundCallStart 0
and the call was dialed (on port 3):
091807.265 6 5 dial StartOutgoingCall start tel[18310755279677] live[] am[] fax[C:\mediasol\customer_files\vg_fax\vg-fax.vgp] onNotAnswered[] onRetriesEnd[] rv[ [ref]{1059} [callnum]{18310755279677} [campaign] {test-fax} [state]{} [postcode]{} [user1]{} [user2]{} [user3]{} [user4]{} [user5]{} [user6]{} [user7]{} [user8]{} [user9]{} [user10]{} [pickupretry] {2} [faxfile]{C:\crco-fax\Fax-Teleseminar-3-easy-ways-09-04-23-ver2.pdf} ] CampaignName[test-fax] options[] ID=2
091807.265 6 5 ls set Dialing
091807.265 6 5 answering machine detection enabled. sCallProgressOption = [DX_PAMDOPTEN]
091807.265 6 5 rv clear all
091807.265 6 5 rv add [ref]{1059}
091807.265 6 5 rv add [callnum]{18310755279677}
091807.265 6 5 rv add [campaign]{test-fax}
091807.265 6 5 rv add [state]{}
091807.265 6 5 rv add [postcode]{}
091807.265 6 5 rv add [user1]{}
091807.265 6 5 rv add [user2]{}
091807.265 6 5 rv add [user3]{}
091807.265 6 5 rv add [user4]{}
091807.265 6 5 rv add [user5]{}
091807.265 6 5 rv add [user6]{}
091807.265 6 5 rv add [user7]{}
091807.265 6 5 rv add [user8]{}
091807.265 6 5 rv add [user9]{}
091807.265 6 5 rv add [user10]{}
091807.265 6 5 rv add [pickupretry]{2}
091807.265 6 5 rv add [faxfile]{C:\crco-fax\Fax-Teleseminar-3-easy-ways-09-04-23-ver2.pdf}
091807.265 6 5 rv add [OutDial_RetriesLeft]{2}
091807.265 6 5 dial making call LineState settings: tel[18310755279677] live[] am[] fax[C:\mediasol\customer_files\vg_fax\vg-fax.vgp] noAnswer[] retriesEnd[] OnHangup[] rv[ [ref]{1059} [callnum]{18310755279677} [campaign] {test-fax} [state]{} [postcode]{} [user1]{} [user2]{} [user3]{} [user4]{} [user5]{} [user6]{} [user7]{} [user8]{} [user9]{} [user10]{} [pickupretry] {2} [faxfile]{C:\crco-fax\Fax-Teleseminar-3-easy-ways-09-04-23-ver2.pdf} [OutDial_RetriesLeft]{2}] options=[]
091807.265 6 5 state Dialing 18310755279677
091807.265 6 5 t timer set 45 sec : EV_TIMEOUT_MAKECALL_NORESPONSE
091807.265 10 dial FindCallQueryCompleted a call was not found. Port= 5, sTaskTimestamp=091807.265, diff=00:00:00
091807.265 6 5 rvns add [OutDial_Result]{NOTCONTACTED}
091807.265 6 5 rvns add [OutDial_Result]{NOANSWER}
091807.265 10 dial state 1:Null,2:Null,3:Dialing,4:Null,5:Null,6:Null,7:Null,8:Null,
091807.265 6 5 ktTel_MakeCall_Enqueue([18310755279677],FAX_CNG, 45,0,0,,) call
091807.265 6 5 qTel add cmd_MakeCall [0,0,45,0,0][||18310755279677|FAX_CNG|]
091807.265 7 5 qTel run cmd_MakeCall
and immediately after dialing the fax script was started:
091809.875 6 5 OnOutboundCallAnswered_Start_SendFax_Option 0,0,0
091809.875 6 5 Set_hCall crn=20000002, called from StartSendingFaxMessage
091809.875 6 5 NewVgsVgm_Goto C:\mediasol\customer_files\vg_fax\vg-fax.vgp,,,,,0
091809.875 6 5 NewVgsVgm_Goto_Setup dest=C:\mediasol\customer_files\vg_fax\vg-fax.vgp|, return=|, lSaveSourceOnCallStack=0
091809.875 6 5 rv add [scriptEnd_Time]{2009-05-28 09:18:09}
091809.875 6 5 rv add [scriptEnd_Goto_Script]{C:\mediasol\customer_files\vg_fax\vg-fax.vgp}
091809.875 6 5 rv add [scriptEnd_Goto_Module]{}
091809.875 6 5 WriteToLogFiles_CurrScriptOnly begin
091809.875 6 5 WriteToLogFiles_CurrScriptOnly : LineState.iVgsIdx<=0
091809.875 6 5 rv add [scriptStart_Time]{2009-05-28 09:18:09}
091809.875 6 5 FindFullPathToScript_VgsOrVgp start [C:\mediasol\customer_files\vg_fax\vg-fax.vgp]
091809.890 6 VgsScriptLoad load start [C:\mediasol\customer_files\vg_fax\vg-fax.vgp]
091809.921 6 5 loaded [C:\mediasol\customer_files\vg_fax\vg-fax.vgp] into:5
091809.921 6 5 rvns add [scriptsPath]{C:\mediasol\customer_files\vg_fax\}
091809.921 6 5 StartModuleDefault=[intro-Msg]
091809.921 6 5 t timer clear (force=False)
091809.921 6 5 RunModule start [Play,[intro-Msg],29]
091809.921 6 5 [intro-Msg] VGMTYPE_PLAY run start
091809.921 6 5 state [intro-Msg] Playing
091809.921 6 5 PrepareAndPlayWavAndTts start iModuleIdx=29, iPlayFileIdx=1, bMakeTtsFile=True, sSoundFileIs=
091809.921 6 5 rv replace start: [$RV[faxfile]]
091809.921 6 5 rvns: [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[ref]{1059}[callnum]{18310755279677}[campaign]{test-fax}[state]{}[postcode]{}[user1]{}[user2]{}[user3]{}[user4]{}[user5]{}[user6]{}[
user7]{}[user8]{}[user9]{}[user10]{}[pickupretry]{2}[faxfile]{C:\crco-fax\Fax-Teleseminar-3-easy-ways-09-04-23-ver2.pdf}[OutDial_RetriesLeft]{2}[OutDial_Result]{NOTCONTACTED}[OutDial_Result]{
NOANSWER}[scriptEnd_Time]{2009-05-28 09:18:09}[scriptEnd_Goto_Script]{C:\mediasol\customer_files\vg_fax\vg-fax.vgp}[scriptEnd_Goto_Module]{}[scriptStart_Time]{2009-05-28 09:18:09}[scriptsPath]{C:\mediasol\customer_files\vg_fax\}
091809.921 6 5 rv replace end: [C:\crco-fax\Fax-Teleseminar-3-easy-ways-09-04-23-ver2.pdf]
091809.921 6 5 PrepareAndPlayWavAndTTS sPlayFile=C:\crco-fax\Fax-Teleseminar-3-easy-ways-09-04-23-ver2.pdf
but there is a bug which results in the fax not being sent. DTMF tones are being sent instead.
091809.921 6 5 state [intro-Msg] Playing dtmf (C:\crco-fax\Fax-Teleseminar-3-easy-ways-09-04-23-ver2.pdf) using PlayStart
091809.921 6 5 qTel add cmd_PlayStart [0,0,0,0,0][||||]
091809.921 6 5 play start ok, playId=253265
091809.921 7 5 qTel run cmd_PlayStart
091809.921 6 2 NewVgsVgm_Goto end
091809.921 6 5 qScr run evScriptEvent TDX_CST, iActionID=0, crn=20000002[27615|0|0|0|0][DE_LCON|||||]
091809.921 6 5 ScriptEvent TDX_CST DE_LCON||
091809.921 6 5 LsPlayMsg EV_UNKNOWN_134,TDX_CST
091809.921 6 5 path {TDX_CST} not found
we will fix this bug in future release of VG.
For now it is possible to workaround this bug by ensuring that the path/filename expression (after $RV replacement) does not start with either letters a,b,c,d,A,B,C,D and does not start with a number.
Easiest way to do this is to use a relative path for the file (relative to the script's location) - that way the path starts with a full stop, something like below:
..\..\crco-fax\Fax-Teleseminar-3-easy-ways-09-04-23-ver2.pdf
or just place file in scripts directory and just specify the fax file's filename without any path in the Play module (first character restrictions as per above would still apply).
The workaround is not simple for us long term.
when would you be fixing the bug. Could you give possible date?
A new version will be released in a couple of weeks.
Another workaround would be to just map another drive letter to the directory where you store the faxes, or just to the C:\ itself.
Use the subst command from the Command prompt (or the autoexec batch file if you want to have this setting done automatically at startup).
eg. if you have:
subst h: c:\
you will be able to specify the fax by using:
h:\crco-fax\Fax-Teleseminar-3-easy-ways-09-04-23-ver2.pdf
instead of
