64bit Windows Support & Voiceguide
Hi, I am currently using v5 TAPI VG (and I am very happy with it as-is) in Windows Server 32 OS.
I wonder, can it be migrated as-is to windows 64bit? ie: does 64bit support TAPI and the VG application?
I know that the TSP will need to work in 64bit too - As I am using comISDN TSP, I will ask them separately.
(looking for more performance on the server)
If 64bit is not support for v5, what about v6/v7 VG?
Thanks - Tim.
64 bit is not supported in v5/v6
Upcoming release of v7 will support Vista 64bit.
Ok, thanks for the prompt reply. I didn't expect 64bit support but had my fingers crossed!
For v7, will 'vista 64bit' work on windows server 64bit (2003/2008) too?
Yes.
But it's the Dialogic drivers that dictate OS selection.
Dialogic drivers support Win2008 (both 32 and 64 bit), but not sure if Dialogic drivers support Win2003 64 bit.
Here are a couple of extracts from the current Dialogic's drivers Release Update.
Dialogic Springware Boards are the only boards supported when using 64-bit versions of
the Windows Vista and Windows Server 2008 operating systems.
The above means that the "DMV" series cards are not supported under 64 bit at this stage.
Also:
Note: Dialogic drivers do not support Physical Address Extensions (PAE). Users using Windows
2003 with Service Pack 1 will have to disable PAE (which is enabled by default in Service Pack 1).
Note: Dialogic drivers do not support more than 4 GB of RAM.
