Guest Matthew Report post Posted 09/23/2003 05:55 AM I am querying an excel sheet with: sheet1B$RV[add one to number]. I did a screen shot of my module/excel sheet, but couldn't post it here (Doesnt' reside on a website). I get to following error when it comes to checking the sheet for row 5, column B: ERROR 5.1.2058 OpenRecordset: 3011:The Microsoft Jet database engine could not find the object 'Sheet1B5'. Make sure the object exists and that you spell its name and the path name correctly. Do I need to format the query differenty, or is there a connectivity problem? I know I pointed the module to the right excel file! Here is the full trace log: 132504.78 0 callstate OFFERING 66201 0 4 132504.80 0 ring 1 132505.84 0 Lev_CallerID [0755030879,] 132507.89 0 ring 2 132510.90 0 ring 3 132510.90 0 Answer the call at 23/09/2003 1:25:10 PM 132510.91 0 lineAnswer(66201) => 66184 132510.92 0 callstate ACCEPTED 66201 0 0 132511.66 0 tapi Reply (LineEvReply) ok 66184 0 132511.67 0 callstate CONNECTED 66201,0,0 132511.68 0 WorkingModeTAPI@Connected= 132511.68 0 WorkingModeScript@Connected= 132511.69 0 Inband detection not enabled 132511.72 0 StartLoadedVgs at 23/09/2003 1:25:11 PM 132511.73 0 [cid] Evaluate [$RV_CIDNUMBER] 132511.74 0 RVreplace start: [$RV_CIDNUMBER] 132511.75 0 RVreplace end: [0755030879] 132511.77 0 .Eval(0755030879) 132511.85 0 Eval Expr result:[755030879] 132511.89 0 [welcome] Playing 132511.90 0 [welcome] Playing (C:\Documents and Settings\Mark41\Desktop\Ivg recordings\Welcome message.wav) 132512.31 0 PlaySoundStart ok [C:\Documents and Settings\Mark41\Desktop\Ivg recordings\Welcome message.wav] 132512.33 0 RunModule PLAY end 132517.85 0 Play End line[0] (id=715652) 132517.87 0 LsPlayMsg EV_PLAY_FINISHED 132519.83 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 132519.84 0 [Get Numbers 3] Number Input 132519.86 0 [Get Numbers 3] Playing (C:\Program Files\VoiceGuide\system\voice\beep1.wav) 132520.27 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\beep1.wav] 132520.47 0 Play End line[0] (id=723604) 132520.48 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED 132522.43 0 dtmf 4 (66201,52,2) 132522.45 0 LsGetNbrsRxDigits 4 132522.46 0 [Get Numbers 3] Number Input 4 132522.48 0 path {4} not found 132522.49 0 [add 1 to number] Evaluate [$RV[Get Numbers 3]+1] 132522.51 0 RVreplace start: [$RV[Get Numbers 3]+1] 132522.52 0 RVreplace end: [4+1] 132522.54 0 .Eval(4+1) 132522.55 0 Eval Expr result:[5] 132522.57 0 path {5} not found 132522.59 0 [Check row entered] DB Query 132522.60 0 Jet mode used (To use ODBC mode specify ODBC Connect string) 132522.87 0 RVreplace start: [sheet1B$RV[add 1 to number]] 132522.88 0 RVreplace end: [sheet1B5] 132522.90 0 About to execute Retrieve Operation [sheet1B5] 132522.94 0 ERROR 5.1.2058 OpenRecordset: 3011:The Microsoft Jet database engine could not find the object 'Sheet1B5'. Make sure the object exists and that you spell its name and the path name correctly. 132522.96 0 [system ssheet error] Playing 132522.97 0 [system ssheet error] Playing (C:\Documents and Settings\Mark41\Desktop\Ivg recordings\system error.wav) 132523.33 0 PlaySoundStart ok [C:\Documents and Settings\Mark41\Desktop\Ivg recordings\system error.wav] 132523.35 0 RunModule PLAY end 132528.37 0 Play End line[0] (id=726718) 132528.39 0 LsPlayMsg EV_PLAY_FINISHED 132530.32 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 132530.33 0 Hanging up call... [Hangup Module] 132530.35 0 RecSoundStop ok 132530.36 0 PlaySoundStop ok 132530.38 0 fnHangupCall end 132531.38 0 callstate DISCONNECTED 66201,1,0 132531.40 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT 132531.41 0 Hanging up call... 132531.43 0 RecSoundStop ok 132531.45 0 PlaySoundStop ok 132531.46 0 fnHangupCall end 132531.48 0 callstate IDLE 66201 0 0 132531.49 0 WorkingMode@Idle= 132531.54 0 tapi Reply (LineEvReply) ok 66167 0 132531.55 0 tapi Reply (LineEvReply) ok 66150 0 132532.47 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 132532.48 0 ReinitTelephony due to IDLE start 132532.52 0 tapic lineDeallocateCall(MainCall:66201) 0 132532.63 0 lineOpen(0) => 0 132532.64 0 Waiting for a call... 132532.66 0 lineOpen(0)LineHandle=66133 Share this post Link to post
SupportTeam Report post Posted 09/23/2003 06:30 AM I did a screen shot of my module/excel sheet, but couldn't post it here You can attach it as a file to the message... (may need to register as a forum member first) I think the problem is that you should use: sheet1$B$RV[add one to number] instead of the current sheet1B$RV[add one to number] The sheet name and cell name should be separated by a "$" Share this post Link to post
jims Report post Posted 09/23/2003 08:28 AM I just tried Sheet1$B$RV[add 1 to number], but jet engine error still came up. I am sure it is pointing to the right excel file! I am looking for data in a particular cell, so should I use Sheet1$B$$RV[add 1 to number] ? Or have I capitalised something that I shouldnt' have? I am running VoiceGuide 5.1.2058 on windows2000. Could this version of VG be my problem, should I try the latest trial version? I really like VG and will buy 2 licences if I can get my script up to scratch! Thanks for the good support! Here is the latest trace log: 155335.18 0 callstate OFFERING 66201 0 4 155335.24 0 ring 1 155336.24 0 Lev_CallerID [0755030879,] 155338.20 0 ring 2 155341.21 0 ring 3 155341.21 0 Answer the call at 23/09/2003 3:53:41 PM 155341.22 0 lineAnswer(66201) => 66184 155341.23 0 callstate ACCEPTED 66201 0 0 155341.96 0 tapi Reply (LineEvReply) ok 66184 0 155341.97 0 callstate CONNECTED 66201,0,0 155341.98 0 WorkingModeTAPI@Connected= 155341.98 0 WorkingModeScript@Connected= 155341.99 0 Inband detection not enabled 155342.02 0 StartLoadedVgs at 23/09/2003 3:53:42 PM 155342.03 0 [cid] Evaluate [$RV_CIDNUMBER] 155342.04 0 RVreplace start: [$RV_CIDNUMBER] 155342.05 0 RVreplace end: [0755030879] 155342.10 0 .Eval(0755030879) 155342.17 0 Eval Expr result:[755030879] 155342.18 0 [welcome] Playing 155342.20 0 [welcome] Playing (C:\Documents and Settings\Mark41\Desktop\Ivg recordings\Welcome message.wav) 155342.60 0 PlaySoundStart ok [C:\Documents and Settings\Mark41\Desktop\Ivg recordings\Welcome message.wav] 155342.62 0 RunModule PLAY end 155348.13 0 wb(40394000) 155348.15 0 Play End line[0] (id=403940) 155348.17 0 LsPlayMsg EV_PLAY_FINISHED 155350.12 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 155350.13 0 [Get Numbers 3] Number Input 155350.14 0 [Get Numbers 3] Playing (C:\Program Files\VoiceGuide\system\voice\beep1.wav) 155350.54 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\beep1.wav] 155350.74 0 Play End line[0] (id=411892) 155350.76 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED 155352.61 0 dtmf 6 (66201,54,2) 155352.63 0 LsGetNbrsRxDigits 6 155352.64 0 [Get Numbers 3] Number Input 6 155352.64 0 path {6} not found 155352.66 0 [add 1 to number] Evaluate [$RV[Get Numbers 3]+1] 155352.68 0 RVreplace start: [$RV[Get Numbers 3]+1] 155352.70 0 RVreplace end: [6+1] 155352.70 0 .Eval(6+1) 155352.73 0 Eval Expr result:[7] 155352.73 0 path {7} not found 155352.75 0 [Check row entered] DB Query 155352.77 0 Jet mode used (To use ODBC mode specify ODBC Connect string) 155353.07 0 RVreplace start: [sheet1$B$RV[add 1 to number]] 155353.09 0 RVreplace end: [sheet1$B7] 155353.10 0 About to execute Retrieve Operation [sheet1$B7] 155353.16 0 ERROR 5.1.2058 OpenRecordset: 3011:The Microsoft Jet database engine could not find the object 'Sheet1$B7'. Make sure the object exists and that you spell its name and the path name correctly. 155353.16 0 [system ssheet error] Playing 155353.19 0 [system ssheet error] Playing (C:\Documents and Settings\Mark41\Desktop\Ivg recordings\system error.wav) 155353.57 0 PlaySoundStart ok [C:\Documents and Settings\Mark41\Desktop\Ivg recordings\system error.wav] 155353.59 0 RunModule PLAY end 155358.61 0 Play End line[0] (id=414926) 155358.61 0 LsPlayMsg EV_PLAY_FINISHED 155400.54 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 155400.55 0 Hanging up call... [Hangup Module] 155400.57 0 RecSoundStop ok 155400.57 0 PlaySoundStop ok 155400.60 0 fnHangupCall end 155401.60 0 callstate DISCONNECTED 66201,1,0 155401.62 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT 155401.63 0 Hanging up call... 155401.65 0 RecSoundStop ok 155401.66 0 PlaySoundStop ok 155401.68 0 fnHangupCall end 155401.69 0 callstate IDLE 66201 0 0 155401.71 0 WorkingMode@Idle= 155401.75 0 tapi Reply (LineEvReply) ok 66167 0 155401.76 0 tapi Reply (LineEvReply) ok 66150 0 155402.68 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 155402.69 0 ReinitTelephony due to IDLE start 155402.73 0 tapic lineDeallocateCall(MainCall:66201) 0 155402.78 0 lineOpen(0) => 0 155402.79 0 Waiting for a call... 155402.81 0 lineOpen(0)LineHandle=66133 Share this post Link to post
SupportTeam Report post Posted 09/23/2003 11:06 AM Looks like the trick is that you always need to specify a range of cells to be retrieved, even if you need to retrieve just one cell. So for example if you needed to retrieve Sheet2$B5 you should specify Sheet2$B5:B5. We have got the same error when using Sheet2$B5 but everything worked OK when using Sheet2$B5:B5. Examples below were made using the modified and then the original "Customer Enquiry" demo script which comes with VoiceGuide. Using Sheet2$B5 210021.17 9 RVreplace start: [sheet$RV[Get Day]$B$RV[Get Roster Number]] 210021.17 9 RVreplace end: [sheet2$B5] 210021.17 9 About to execute Retrieve Operation [sheet2$B5] 210021.19 9 ERROR 5.1.2068 OpenRecordset: 3011:The Microsoft Jet database engine could not find the object 'Sheet2$B5'. Make sure the object exists and that you spell its name and the path name correctly. Using Sheet2$B5:B5 210113.56 9 RVreplace start: [sheet$RV[Get Day]$B$RV[Get Roster Number]:B$RV[Get Roster Number]] 210113.56 9 RVreplace end: [sheet2$B5:B5] 210113.56 9 About to execute Retrieve Operation [sheet2$B5:B5] 210113.56 9 [Excel Query] row count=1 Share this post Link to post
Guest Matthew Report post Posted 09/25/2003 04:21 AM Thanks for great help. It is working fine now! Share this post Link to post
