Caller Id Not Recognised
My modem Intel V92 Ham Data Fax Voice is tested to support caller ID through Hyperterminal. But the same does not detect caller ID when attending the rings received by Voice Guide. I am using version 5 of Voice Guide. The log shows Inband detection not anabled. Any way out please?
You will need to speak to your modem manufacturer. Perhaps changing the modem's .INF file or some setting in the modem's TAPI driver can fix this issue.
I had it verifed from modem manual. The required extra initialization string was already copied AT+VCID=1. Any other clues?
You really would need to contact the modem manufacturer. Each modem is a bit different then another.
You could experiment with using different settings for the modem. Some people use "Rockwell Voice Modem" driver settings.
You are likely to spend a lot of time on this with no solution. This is why we recommend they not be used.
