lesccseh Report post Posted 06/11/2009 01:48 PM hi .. i wrote a simple script to receive faxes. watching the status monitor, the call is answered and the status says it is recording, but: a) the fax sender (which i have beside me) still only says "dialing" there is no exchange of tones that you usually hear when faxes start is there something else i need to configure or do? i am using the vg7 demo and a dialogic d/120jct-ls. and i tested one of your voice recording scripts on the same line and that worked ok (although i have not tested playing yet, only recording). regards, les Share this post Link to post
SupportTeam Report post Posted 06/11/2009 09:15 PM Could you please post a copy of VoiceGuide's Traces which captures the call, this will allow us to see what happened. Trace files are be created in VG's \log\ subdirectory. Please post the traces and the VoiceGuide script used. When posting traces/scripts please .ZIP them up and post them as attachments. Share this post Link to post
lesccseh Report post Posted 06/11/2009 09:47 PM here is the info you requested. i have stripped the script down to nothing more than a record, specifying a hard-coded filename ending in .tif 4325184_faxreceive_090611.ZIP Share this post Link to post
SupportTeam Report post Posted 06/11/2009 10:54 PM Your incoming call arrives on line dxxxB3C3 - that is the 11th line on system. On that line you have this script specified to be used: C:\Program Files\VoiceGuide\Scripts\Answer and Record\Answer and Record.vgs as per this Config.xml entry: <Channel> <Name>dxxxB3C3</Name> <NetworkIf>dxxxB3C3</NetworkIf> <Protocol>pdk_na_an_io</Protocol> <RingsBeforeAnswer>2</RingsBeforeAnswer> <script>C:\Program Files\VoiceGuide\Scripts\Answer and Record\Answer and Record.vgs</Script> <ConfigLine></ConfigLine> <AllowDialOut>1</AllowDialOut> <RV></RV> </Channel> The C:\ASAP\apps\telephony\VoiceGuide Scripts\fax receive.vgs script that you want to run has been configured in Config.xml to run for calls arriving on line dxxxB3C4 (12th line), not on dxxxB3C3. relevant part of vgEngine trace showing on which line call arrived: 173241.109 6 20 rvns add [scriptPath]{C:\Program Files\VoiceGuide\Scripts\Answer and Record\} 173241.125 6 20 rvns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Answer and Record\} 173241.125 6 20 set sScriptToRunOnHangup=[] in StartLoadedVgs 173241.125 6 20 rv add [$RV_STARTTIME]{2009-06-11 17:32:41} 173241.125 6 20 rv add [$RV_DEVICEID]{20} 173241.125 6 20 rv add [DlgcVoice]{dxxxB3C3} 173241.125 6 20 rv add [DlgcNetwork]{dxxxB3C3} 173241.125 6 20 rvns add [PathApp]{C:\Program Files\VoiceGuide\} 173241.125 6 20 rvns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\Answer and Record\} 173241.093 20 20 ev Dialogic 134,TDX_CST, crn=10000001, 0,0,0,DE_RINGS,ET_RON, 173241.140 20 20 qScr add evScriptEvent 134 TDX_CST 173241.265 6 20 t timer clear (force=False) 173241.265 6 20 RunModule start [Record,[Record Coversation],13] 173241.265 6 20 [Record Coversation] VGMTYPE_REC run start 173241.265 6 20 answering the call (picking up the line) ... 173241.828 6 20 RunModule start [Record,[Record Coversation],13] 173241.828 6 20 [Record Coversation] VGMTYPE_REC run start 173241.859 6 20 rv replace start: [$RV_CIDNUMBER_$RV_CIDNAME_$RV_MM$RV_DD_$RV_HH$RV_NN$RV_SS.wav] 173241.859 6 20 rv add [Record Coversation]{C:\Program Files\VoiceGuide\Scripts\Answer and Record\__0611_173241.wav} Share this post Link to post
lesccseh Report post Posted 06/11/2009 11:13 PM sorry abou tthe confusion, some earlier attempts had that. but i originally had the fax script on 11, then installed the answer one to see if it was my script, and later tried the fax script on 12 as well. the result was always the same. Share this post Link to post
SupportTeam Report post Posted 06/12/2009 01:51 AM So does this mean that you have now resolved the configuration issue and it is now working? If you are still having problems then post the traces as before, showing the call being answered by your fax script. Share this post Link to post
lesccseh Report post Posted 06/12/2009 02:44 AM Hi, no, the problem remains has not changed. And if the logs don't show what i am describing, I am at a loss what to do next. As mentioned before, when I watch the line status monitor, I see that it shows that the fax receive script is recording, but the sending fax app shows it is waiting for an answer, and there is certainly no fax ever transmitted/saved. I never hear those "handshake" tones that you normally hear when fax machines talk to each other. Share this post Link to post
SupportTeam Report post Posted 06/12/2009 03:48 AM To let us comment on what is happening with a fax script we must have a trace showing that fax script running when the call is answered. Not some other script. Post the traces capturing the fax script running when call is answered and we can then tell you what is happening. Share this post Link to post
lesccseh Report post Posted 06/12/2009 12:25 PM hmm, i thought that what i had sent included that. in any case, here is a new zip file from this morning using a new fax receive script that you guys just delivered, along with the log files. the behavior remains the same. 4325184_faxreceive_090612.ZIP Share this post Link to post
SupportTeam Report post Posted 06/12/2009 01:03 PM Trace shows the Dialogic drivers report that this card does not support Fax. Is this a current model D/120JCT or an older card? Do you have the full model number and revision number for this card? Is it displayed as a D/120JCT in the DCM? 080932.640 1164 22 LineOpen (analog) ok => [22] 080932.671 1164 22 fx_open => -1, fax not supported on device dxxxB3C4. ... 081522.500 1164 22 fn Fax_Rx_Start(sFile=C:\S1-TRANSFER\Fax\Chequeco\ccccccF-090612081522-N-I.tif, sOptions=) 081522.515 1164 22 Fax_Rx_Start(sFile=[C:\S1-TRANSFER\Fax\Chequeco\ccccccF-090612081522-N-I.tif], sOptions=[]) 081522.515 1164 fax device not opened on this line. Aborting fax receive. Share this post Link to post
lesccseh Report post Posted 06/12/2009 01:46 PM interesting. dcm shows: dialog/hd-pci d/120jct-ls #0 in slot 1/10 it was purchased used, but thought i had read somewhere that all of these models supported fax. is it possible that it is just not configured properly, or do i need to scramble to get a newer d/120jct-ls that supports fax? lcc. Share this post Link to post
lesccseh Report post Posted 06/12/2009 02:03 PM the diagnostics show #FW010737 .. if that is not the revision number let me know and I will dig further. Share this post Link to post
SupportTeam Report post Posted 06/12/2009 08:39 PM FW010737 is the serial number of the card. Do you have the product code of the card? It will be on the sticker on the card somewhere. It should look something like this: 99-3931-123 Do any stickers or printing on the card say whether this card is "Rev 1" or "Rev 2" etc ? Not sure if the old D/120JCTs did not support fax. We mostly work with current production models and they do support fax tx/rx. There should be some demo programs installed by Dialogic drivers in the Dialogic driver directory. Can you try running the fax demo programs and see if they work on your card? Share this post Link to post
lesccseh Report post Posted 06/12/2009 10:00 PM i should have this shortly, but i have an urgent question first that I could not find answered on your site or in the support forums. can i use vg 7 with a dialogic cpi/400 for the fax receiving? les Share this post Link to post
lesccseh Report post Posted 06/12/2009 10:15 PM My d/120jct-ls has a product code of 85-0546-204 rev. B. I am about to try another one that has the same product code but is rev. D. Share this post Link to post
SupportTeam Report post Posted 06/12/2009 10:21 PM cpi/400 is not supportd. It is an older card. The current model D/41JCT supports fax so basically the D/41JCT has all the features of cpi/400 and does voice/speech./etc as well and is cheaper then cpi/400. Most likely you have an old D/120JCT that does not support fax. Probably best thing for you to do is to get a current model D/120JCT (on a trial basis with option to return if you'd like). Share this post Link to post
lesccseh Report post Posted 06/12/2009 10:46 PM thanks for the quick reply. last question on this i hope- the D/41JCT-LS is appealing. should i be able to run the d/120jct-ls for voice lines and the d/41jct-ls for 4 fax lines, in the same pc, all with vg 7? les Share this post Link to post
SupportTeam Report post Posted 06/12/2009 11:09 PM should i be able to run the d/120jct-ls for voice lines and the d/41jct-ls for 4 fax lines, in the same pc, all with vg 7? Yes. Share this post Link to post
SupportTeam Report post Posted 06/12/2009 11:47 PM Recommend ensuring that a current release D/41JCT is used, to ensure that Fax is supported by the card. It is hard to establish is all of the old used D/41JCT cards out there support Fax. Probably best thing to do is to procure the D/41JCT on a trial basis with option to return if you find that it does not do fax for some reason. Share this post Link to post
lesccseh Report post Posted 06/13/2009 02:13 PM *thanks*, will do. i have been trying to find out how to change config.xml for 1 x d/120jct-ls and 1 x d/41jct-ls but so far no luck. is there a sample available? Share this post Link to post
SupportTeam Report post Posted 06/13/2009 09:37 PM You can use the <Channels> section from sample this file: Sample Config for 16 port using analog DMV160LS card.xml That file contains a definition for 16 analog lines. Have a look at the device names - you see that in Dialogic's naming structure there are 4 'Channles' per 'Board'. First voice device is dxxxB1C1 Second voice device is dxxxB1C2 3rd is dxxxB1C3 4th is dxxxB1C4 5th is dxxxB2C1 6th is dxxxB2C2 7th is dxxxB2C3 8th is dxxxB2C4 9th is dxxxB3C1 etc etc you just specify as many <Channel> entries in the Config.xml as necessary. Share this post Link to post
lesccseh Report post Posted 06/13/2009 09:42 PM thanks, although i'm still unclear because i used that exact naming system for the 12 ports/channels on the d/120jct-ls. if i add the d/41jct to the same system, then do its ports/channels just continue on in sequence? (that is, 12 d/120 + 4 d/41 are in the same config.xml, in the same <channel> section)? Share this post Link to post
SupportTeam Report post Posted 06/13/2009 09:47 PM Yes. The Dialogic drivers find all cards in system and place one card and its resources (lines) in sequence one after another. Note that you need to have the JCT cards linked by the CTBus cable. Else the Dialogic drivers will not be able to work properly. Share this post Link to post
lesccseh Report post Posted 06/15/2009 04:41 PM A quick update: - someone at Dialogic advised me that all of the d/120jct boards are fax-capable, and showed me how to have the fax firmware loaded. from what i can see in the logs, i no longer get the 'fax not supported' messages. - i still cannot receive a fax, but it is operating a bit differently. the sender still does not receive the fax handshaking tones and eventually hangs up saying 'not answered'. however, upon answering, vg records (the silence) to a .tif file. i have attached the most recent logs and script. can you see why the fax handshaking is not occurring? and shouldn't recording only start upon successful fax handshake? les 4325184_faxreceive_090615.ZIP Share this post Link to post
SupportTeam Report post Posted 06/15/2009 09:05 PM Trace shows same as before: 111923.281 2380 22 LineOpen (analog) ok => [22] 111923.296 2380 22 fx_open => -1, fax not supported on device dxxxB3C4. ... 112305.312 2380 22 fn Fax_Rx_Start(sFile=C:\asap\messages\ccccccF-090615112305-N-I.tif, sOptions=) 112305.328 2380 22 Fax_Rx_Start(sFile=[C:\asap\messages\ccccccF-090615112305-N-I.tif], sOptions=[]) 112305.328 2380 fax device not opened on this line. Aborting fax receive. trace shows that every time the system was restarted the fax resources could not be opened on any of the ports on this card: 0615_ktTel.txt:102936.750 1092 1 fx_open => -1, fax not supported on device dxxxB1C1. 0615_ktTel.txt:102936.843 1092 2 fx_open => -1, fax not supported on device dxxxB1C2. 0615_ktTel.txt:102936.921 1092 4 fx_open => -1, fax not supported on device dxxxB1C3. 0615_ktTel.txt:102937.015 1092 6 fx_open => -1, fax not supported on device dxxxB1C4. 0615_ktTel.txt:102937.093 1092 8 fx_open => -1, fax not supported on device dxxxB2C1. 0615_ktTel.txt:102937.171 1092 10 fx_open => -1, fax not supported on device dxxxB2C2. 0615_ktTel.txt:102937.250 1092 12 fx_open => -1, fax not supported on device dxxxB2C3. 0615_ktTel.txt:102937.453 1092 14 fx_open => -1, fax not supported on device dxxxB2C4. 0615_ktTel.txt:102937.593 1092 16 fx_open => -1, fax not supported on device dxxxB3C1. 0615_ktTel.txt:102937.687 1092 18 fx_open => -1, fax not supported on device dxxxB3C2. 0615_ktTel.txt:102937.765 1092 20 fx_open => -1, fax not supported on device dxxxB3C3. 0615_ktTel.txt:102937.843 1092 22 fx_open => -1, fax not supported on device dxxxB3C4. 0615_ktTel.txt:105224.406 1068 1 fx_open => -1, fax not supported on device dxxxB1C1. 0615_ktTel.txt:105224.515 1068 2 fx_open => -1, fax not supported on device dxxxB1C2. 0615_ktTel.txt:105224.609 1068 4 fx_open => -1, fax not supported on device dxxxB1C3. 0615_ktTel.txt:105224.687 1068 6 fx_open => -1, fax not supported on device dxxxB1C4. 0615_ktTel.txt:105224.765 1068 8 fx_open => -1, fax not supported on device dxxxB2C1. 0615_ktTel.txt:105224.859 1068 10 fx_open => -1, fax not supported on device dxxxB2C2. 0615_ktTel.txt:105224.921 1068 12 fx_open => -1, fax not supported on device dxxxB2C3. 0615_ktTel.txt:105225.015 1068 14 fx_open => -1, fax not supported on device dxxxB2C4. 0615_ktTel.txt:105225.265 1068 16 fx_open => -1, fax not supported on device dxxxB3C1. 0615_ktTel.txt:105225.531 1068 18 fx_open => -1, fax not supported on device dxxxB3C2. 0615_ktTel.txt:105225.625 1068 20 fx_open => -1, fax not supported on device dxxxB3C3. 0615_ktTel.txt:105225.796 1068 22 fx_open => -1, fax not supported on device dxxxB3C4. 0615_ktTel.txt:111922.203 2380 1 fx_open => -1, fax not supported on device dxxxB1C1. 0615_ktTel.txt:111922.281 2380 2 fx_open => -1, fax not supported on device dxxxB1C2. 0615_ktTel.txt:111922.359 2380 4 fx_open => -1, fax not supported on device dxxxB1C3. 0615_ktTel.txt:111922.453 2380 6 fx_open => -1, fax not supported on device dxxxB1C4. 0615_ktTel.txt:111922.531 2380 8 fx_open => -1, fax not supported on device dxxxB2C1. 0615_ktTel.txt:111922.609 2380 10 fx_open => -1, fax not supported on device dxxxB2C2. 0615_ktTel.txt:111922.703 2380 12 fx_open => -1, fax not supported on device dxxxB2C3. 0615_ktTel.txt:111922.765 2380 14 fx_open => -1, fax not supported on device dxxxB2C4. 0615_ktTel.txt:111922.859 2380 16 fx_open => -1, fax not supported on device dxxxB3C1. 0615_ktTel.txt:111923.140 2380 18 fx_open => -1, fax not supported on device dxxxB3C2. 0615_ktTel.txt:111923.218 2380 20 fx_open => -1, fax not supported on device dxxxB3C3. 0615_ktTel.txt:111923.296 2380 22 fx_open => -1, fax not supported on device dxxxB3C4. My d/120jct-ls has a product code of 85-0546-204 rev. B. This looks like a very old card. Can you see any screen printing on the card that would indicate the year it was made? Share this post Link to post
lesccseh Report post Posted 06/15/2009 09:19 PM 1999. so far, every response from dialogic has been that fax should be supported on all models (i provided the model number to them too). will the excerpt from kttel.txt be useful to send to them, or is there something else i need to provide to them to help get a definitive answer? thx for your help, les Share this post Link to post
SupportTeam Report post Posted 06/15/2009 09:58 PM Have you tried running the Dialogic fax demo app and see if it works with this board? The fax demo should be one of the sample apps installed by the Dialogic drivers. Share this post Link to post
SupportTeam Report post Posted 06/16/2009 04:21 AM We had a look around the lab for older D/120JCT cards and have found 4. Three have "1999" screen printed on them, and one has "2001" screen printed on it. The 1999 cards have a white sticker that says "85-0546-204 REV B" - same as your card ! The 2001 card has a white sticker that says "85-0546-401 REV A" We placed the cards in our test server (SR60 used) and set FirmwareFile setting to spfax.fwl in the DCM's Mics tab. None of the 1999 cards were able to open fax devices. Dialogic's own demo programs could not open any fax devices either. The 2001 card was able to open fax devices on four of it's ports: dxxxB1C1, dxxxB1C2, dxxxB3C1 and dxxxB3C2. This is as expected, as: "with spfax.fwl firmware, the D/120JCT-LS has the capability of using 4 fax resources. Two can be used in the first 8 channels, and 2 more can be used in the last 4 channels. It doesn't matter which 2 in either group, but only two at a time in each group can be used as fax resources." Looks like if you want to try using old D/120JCT cards to implement fax services it may be a good idea to look at cards that are designed after 2001. As advised before, to save yourself time doing trial and error tests you may just want to get a current model D/41JCT. Share this post Link to post
lesccseh Report post Posted 06/16/2009 10:21 AM thank you very much. i regret that dialogic misinformed me about these older boards. les Share this post Link to post
lesccseh Report post Posted 06/19/2009 01:59 AM i am a big step closer, but still missing something. purchased a newer d/41jct-ls from an experienced vendor who explained some of the differences. on this newer one, i can run the dialog fax demo app (did the negotiation and received a fax which it recorded to a tif file) .. woo-hoo however when i then tried the same vg script i have been trying to use, to the same port on the d/41jct-ls, the results were the same. it answers, but there is no handshake/negotiation and it starts recording the silence to a tif file. the latest logs/etc. are attached. Share this post Link to post
lesccseh Report post Posted 06/19/2009 02:13 AM oops, here is the attachment. note that i am still using the config of board 0 d/120jct-ls (8 of the 12 lines configured in config.xml, for voice) and board 2 d/41jct-ls (4 lines configured in config.xml, for fax). the boards are connected via ctbus. and as mentioned in the previous post, the dialog fax sample was able to receive to one of the fax ports on the d/41 les 4325184_faxreceive_090618.ZIP Share this post Link to post
SupportTeam Report post Posted 06/19/2009 03:50 AM It is possible that in the version that you are using right now there is bug which results in VoiceGuide only doing fax send/receive is the filename uses lowercase ".tif", ".tiff", ".pdf" suffixes. Please try specifying the filename expression with ".tif" or ".pdf" on end and see if this works. This lowercase dependence bug has been fixed and fix will be included in future releases. Share this post Link to post
lesccseh Report post Posted 06/19/2009 01:16 PM hallelujah. my d/41jct-ls is now receiving faxes. and i love the feature where you automatically generate a pdf from the tif file. i now have several old model non-fax capable d/120jct-ls and d/41jct-ls to arrange to return to those that sold them claiming they were fax capable <g> les Share this post Link to post
