Guest Jonah Report post Posted 06/11/2009 02:59 PM Currently we are running 1 480JCT-1T1 card with 23 VoiceGuide lines. We are wanting to upgrade the server to handle twice that many lines. Are there any issues with installing 2 of these boards in the same server with VoiceGuide? Share this post Link to post
SupportTeam Report post Posted 06/11/2009 09:05 PM No issues with running multiple 480JCT-1T1 cards in one system. Multiple JCT and DMV Dialogic cards can be installed on same system in any combination. If from the outset it is known that multiple T1/E1 lines will be used on system then we usually recommend using DMV series cards. DMV is a newer series then JCT. Share this post Link to post
Guest Jonah Report post Posted 06/11/2009 09:21 PM What is the best DMV card to get to support 2 T1 lines (48 ports) and what are the main differences? Share this post Link to post
SupportTeam Report post Posted 06/11/2009 09:31 PM For new 2 T1/E1 line systems we'd recommend using DMV600B. For new 4 T1/E1 line systems we'd recommend using DMV1200B. see: http://www.dialogic.com/products/tdm_board..._Boards_DM3.htm In your situation as you already have a 480JCT-1T1 the best thing to do is to buy another 480JCT-1T1 and place it in same system. Share this post Link to post
