TetecBV Report post Posted 06/12/2009 09:02 AM Hello Support Team, I've tried to install Voiceguide on several machines but I won't get it work. I've searched the forum for answers but can't find them. Some facts: - First I have installed HMP3.0 (241) - Request a demo license (2port) and activated it in DCM - Started to run DCM - Installed Voiceguide 7.0.9 succesfull - Opened the config.xml file and remove channel 2,3 and 4 - Inserted the voip account - With a sipphone I log on using sipserver: vpbx.12connect.com username: 999105578 password: ******** - My system: Windows XP sp3 - This computer is in a small business network behind a router (192.168.1.74) The problem starts with nothing to see in the line status monitor. Can u check what I've done wrong? Here are the log, config and wireshark files. With kind regards, Theo log.zip Share this post Link to post
SupportTeam Report post Posted 06/12/2009 12:58 PM Did you select all the options when installing the HMP? ktTel trace show that even the basic Dialogic library can't be started, so perhaps the 'Global Call" option was not installed? 100433.890 448 ERROR gc_start Share this post Link to post
TetecBV Report post Posted 06/12/2009 04:54 PM The attached file show's the futures i've installed with HMP, I don't see the option 'Global Call'. Where can I find this option? Kind regards, Theo HMPfeaturesinstalled.zip Share this post Link to post
SupportTeam Report post Posted 06/12/2009 09:28 PM If all options are selected then it should be fine. The screenshot looks like it has come from Vista. Which version of Windows are you running, Vista or XP? As the Dialogic drivers are not starting up then only advise we can give is to try re-installing HMP, and if that does not work then try starting with a clean system - just WindowsXP and HMP and see if you can get any of the the Dialogic demo programs working. Is this system Intel based or AMD based? Share this post Link to post
