Enabling Caller Id On D/120jct-ls
hi. i am not picking up caller id with a d/120jct-ls. i have set config.xml to answer after 2 rings.
is there something else i need to set?
logs, script, configs are attached. look at the last call in the log.
thanks,
les
4325184callerid_090615.ZIP
well, this *will* be used with a pbx but this was testing with a regular residential voice line where caller id is definitely supplied.
Perhaps the old (1999 make) D/120JCT card that you are using is unable to detect the CallerID sent by the Telco.
You would need to establish what CallerID formats your card supports and then see if it includes the format in which your Telco sends the CallerID.
