Amaflags
How can i populate the AMAFLAGS files that appears in the CdrOut table. What DB column is populated during a load to cause this to be populated in the CdrOut table
In the documentation it is described as:
amaflags: Billing flags (string)
Jeff
This field is not written to at this stage.
In future update releases we will add a $RV[CDR_amaflags]
The value of $RV[CDR_amaflags] will be stored in the amaflags field. The $RV[CDR_amaflags] can be set at call load time or from within the script.
NB.
We may also add an additional field to the CDR log and corresponding database table: user
The value of $RV[CDR_user] will be stored in the user field. The $RV[CDR_user] will be able to be set at call load time or from within the script.
per previous post, is $RV[CDR_amaflags] and $RV[CDR_user] now available in 7.1
thanks
Just did some testing
$RV[CDR_amaflags] - works. When passed in it is stored in the cdrout amaflags column
$RV[CDR_user] - does not work. When passed in it is NOT stored in the cdrout usr column
Please .ZIP up and post the VgEngine trace capturing the call and the writing of CDR logs. We can then see what is happening on the system.
$RV[CDR_user] works ok Now. It was my fault. I had an extra space in the RV name in the code. Once removed, worked great
