health4us Report post Posted 09/23/2003 12:20 PM I am trying to play a few files at once... When i play the wav files everything works but as soon as i add the TEXT TO SPEECH text file it tells me there was an error playing the file.. If i play the TTS file on it's own it works ok. Please help with this thanks Matt 141143.08 0 dial callque update id=1006 next call time 0309231611 141143.09 0 dial callque DB update returned 141143.09 7 dial found entry: tel[1051661180060] ann[NONE] vgs[C:\Program Files\VoiceGuide\Scripts\recruitment\new.vgs] am[NONE] 141143.09 7 Calling MakeCallEx(1051661180060) 141143.09 7 Dialing: 1051661180060 141143.09 7 MakeCall => 66122 141143.09 7 TapiCbTrigSet 66122 7002 141143.84 7 tapi Reply (LineEvReply) ok 66122 0 141143.84 7 TapiCbTrigClear 141143.84 7 linedevstate 2048 0 0 141143.84 7 callstate DIALTONE 65575 0 0 141143.84 7 callstate DIALING 65575 0 0 141143.84 7 callstate PROCEEDING 65575 0 0 141143.84 7 callinfo CALLEDID 141143.85 7 callinfo REASON 141143.85 7 Lev_CallerID [01423325554,] 141143.85 7 callinfo ORIGIN 141153.63 7 callstate CONNECTED 65575,1,0 141153.63 7 WorkingModeTAPI@Connected= 141153.63 7 WorkingModeScript@Connected= 141153.65 0 dial callque delete id=1006 141153.65 7 Live person answered, starting C:\Program Files\VoiceGuide\Scripts\recruitment\new.vgs 141153.65 2 tr NewVgsVgm_Goto C:\Program Files\VoiceGuide\Scripts\recruitment\new.vgs,,,,,0 141153.66 0 LoadedVgs_Find C:\Program Files\VoiceGuide\Scripts\recruitment\new.vgs at idx=6 141153.66 7 cl NewVgsVgm_RunModule module not found: 141153.66 2 tr NewVgsVgm_Goto 1 141153.66 2 tr NewVgsVgm_Goto 2 141153.66 7 [GetClientRecord] DB Query 141153.66 7 Jet mode used (To use ODBC mode specify ODBC Connect string) 141153.67 7 RVreplace start (strlen>100) 141153.67 7 About to execute Retrieve Operation [sELECT Title, Name, Surname, UKPhoneNumber, CallersName, CallStatus, LeadSource, CallSubject, Address1, Address2, Address3, City, County, Postcode, CallersEmail FROM NamesList WHERE PhoneNumber=1051661180060] 141153.77 7 [GetClientRecord] row count=1 141153.78 7 [intro] Playing 141153.78 7 [intro] Playing (recruitment\tts-name.txt, recruitment\rec- live-call-filter-message1.wav, recruitment\rec- live-call-filter-message2-info.wav) 141153.78 7 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>2] file[C:\Program Files\VoiceGuide\Scripts\recruitment\tts-name.txt,C:\Program Files\VoiceGuide\Scripts\recruitment\rec- live-call-filter-message1.wav,C:\Program Files\VoiceGuide\Scripts\recruitment\rec- live-call-filter-message2-info.wav] 141153.81 7 RunModule PLAY end 141153.82 2 tr NewVgsVgm_Goto end 141153.82 7 tapie PlayEnd old line=7 0 978458 141158.31 7 wb(97845800) 141159.32 7 Play End line[7] (id=978458) 141159.32 7 LsPlayMsg EV_PLAY_FINISHED 141159.32 7 Hanging up call... [No Paths leaving Play module [intro]] 141159.32 7 RecSoundStop ok 141159.32 7 PlaySoundStop ok 141159.32 7 fnHangupCall end 141159.37 7 linedevstate 2048 0 0 141159.37 7 callstate IDLE 65575 0 0 141159.37 7 WorkingMode@Idle= 141159.39 7 tapi Reply (LineEvReply) ok 66156 0 141200.33 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 141200.33 7 ReinitTelephony due to IDLE start 141200.33 7 tapic lineDeallocateCall(MainCall:65575) 0 141200.49 7 lineOpen(7) => 0 141200.49 7 Waiting for a call... 141200.50 7 lineOpen(7)LineHandle=66276 Share this post Link to post
SupportTeam Report post Posted 09/23/2003 02:04 PM This trace does not show VoiceGuide doing any real-time TTS - it looks like all the supplied files have been pre-recorded... Are all the sound files in correct format? Will the 3 files play OK from 3 successive Play modules? If all sound files are in the same format and play separately OK - just not play when they are all together could you please zip up the 3 files and post them here and we can have a look at them. Also please place the attached file in "C:\" and include in the .zip the trace file C:\TapiWrapLogMMDD.txt which captures more debug information. The file TapiWrapLogMMDD.txt will be created in "C:\" TapiWrapLogSelect.txt Share this post Link to post
