Guest neutroz Report post Posted 07/14/2009 04:13 PM Hello, I have VoiceGuide 7 with a dialogic 4 line analog card. I have a script that runs so that people can call in and leave a voicemail. on {1} goto [Voicemail Box 001] return [Hangup] Most of the Voicemails are received fine, but occassionally when a person calls in that has very low audio on the line Voiceguide hangs up shortly after the person starts leaving the message. There is no disconnect tone on the line (I checked using audacity). I opened the VmLmRec module in the VmLm.vgs script and removed the following line... on {silence} goto [VmLmHangup] It still hangs up the call shortly after it begins recording. I have even tried bumping up the gain on the Dialogic card. Any ideas? I have attached the logs from a call that is being hungup on. 0714_1040_vgEngine.txt 0714_ktTel.txt Share this post Link to post
SupportTeam Report post Posted 07/14/2009 10:04 PM A Record module will stop recording when silence is detected. If silence path is not defined in the Record module then VoiceGuide will just hang up. This is what is happening here: 104118.937 6 1 path {silence} not found 104118.937 6 1 HangupCall, source={silence} path not defined, WorkModeScript=Running_Normal, yLineStateAppPov=[Connected], lPlayId=0, lRecId=0 ... 104118.937 6 1 state Hanging up... [{silence} path not defined] You can adjust the minimum silence length time when using Dialogic cards (see: http://www.voiceguide.com/vghelp/source/html/modrecord.htm), but would not recommend that you change those values as the default settings work well for normal non-problem calls. The real issue here is that some calls delivered to the system have very low audio signal and you should work with PBX manager or Telco to resolve this issue. Share this post Link to post
Guest neutroz Report post Posted 07/15/2009 03:58 AM Thank you. I will pursue with the telco provider. I'm thinking that possible a few trunks are bad as it doesn't happen more than 25% of the time. Share this post Link to post
