Text To Speech
I am using VoiceGuide 7. Have installed the microsoft speech sdk 5.1.
If i want to change the voice to Microsoft Mary or some other, what value do i type in the vg.ini?
I have not changed the vg.ini at all to begin with.
TTSEngine=
I did read the following link but i am not able to figure out what do I change to accomplish what i want.
http://www.voiceguide.com/vghelp/source/html/config_tts.htm
thanks for your help in advance.
Have you installed other TTS engines on this system? Which ones?
Please post the most recent ktTts log file from VoiceGuide's \log\ subdirectory.
No i don't think there is any other TTS in the system.
I just want to change the voice from the default voice to some other. I would like to know how?
Thanks in advance,
Log:
100929.640 2592 ------------------------------------------------------------------------------
100929.640 2592 ktTtsSapi v2.1
100929.640 2592 Apr 23 2009 15:01:00
100929.640 2592 zsLogPath [C:\Program Files\VoiceGuide7\log\]
100929.640 2592 ProcessAnyQueuedTTSJobs CreateThread call
100929.640 2592 ProcessAnyQueuedTTSJobs CreateThread returned
100929.640 1864 ProcessAnyQueuedTTSJobs thread started
100929.640 1864 CoInitialize(NULL) call
100929.906 1864 alloc szDescription (CSpDynamicString)
100929.906 1864 alloc ppszTokenIds (WCHAR)
100929.906 1864 ZeroMemory call
100929.906 1864 SpEnumTokens call
100929.906 1864 SpEnumTokens returned ok
100929.906 1864 GetCount call
100929.906 1864 GetCount returned ulNumTokens=4
100929.906 1864 il SpGetDescription call
100929.906 1864 il GetId call
100929.906 1864 il wtoc + _wcsicmp calls
100929.906 1864 il voice 0 is: [Microsoft Sam], ID=[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Speech\Voices\Tokens\MSSam]
100929.921 1864 il wtoc + _wcsicmp calls
100929.921 1864 il voice 1 is: [Microsoft Mike], ID=[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Speech\Voices\Tokens\MSMike]
100929.921 1864 il SpGetDescription call
100929.921 1864 il GetId call
100929.921 1864 il voice 2 is: [Microsoft Mary], ID=[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Speech\Voices\Tokens\MSMary]
100929.921 1864 il voice 3 is: [sample TTS Voice], ID=[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Speech\Voices\Tokens\SampleTTSVoice]
In VG.INI please set:
TTSEngine=Microsoft Mary
Then restart VoiceGuide service.
If you still have problems please post a copy of VoiceGuide's Trace Logs which captures the call, this will allow us to see what happened.
Thanks a lot for you help, I was able to change the voice.
Are there any other TTS engines that you would recommend which can be used?
