Troubles After The Licence Activation
after activating the license, indeed the IVR answer calls (even though the call occurs more after an hour) but in this case only accepts DTMF data for a few seconds and then cuts the communication. we sent this information together thelogs generated by the system on july 17 to the email address:
sales@voiceguide.com
now we wait for your support.
thanks
Could you please post a copy of VoiceGuide's Traces which capture the call, this will allow us to see what happened.
The attached files are not VoiceGuide logs. The VoiceGuide logs can be found in VoiceGuide's \log\ subdirectory. ie. usually in: C:\Program Files\VoiceGuide\log\
If using v7 these log files are created automatically.
If using v5 or v6 the logs need to be first enabled in the VG.INI:
[Log]
VoiceGuide=10
NumberLoader=0
VoicemailManager=0
EmailSender=0
TapiWrapOcx=10
SapiWrapOcx=0
Then make a test call which demonstrates the problem.
