Capture Entered Number Script Not Capturing #s
Using VG version #7.0.9
I've created a script (see attached) that would play a short sound file, capture a person's dialed numbers. Depending on whether it succeeds or fails, it will go to another module with a short sound file that says "fail" or "success."
When I make the calls and try to enter numbers, it doesn't seem to ever go to the "success" module. After the numbers I've entered, I've tried hitting # and * but it still goes to the fail module.
Please help, perhaps I'm doing something incorrectly.
TS_Responses_Human.vgs
Could you please post a copy of VoiceGuide's Traces which captures the outgoing call, this will allow us to see what happened.
Trace files are created in VG's \log\ subdirectory.
There are many calls included in the traces so not sure which call we should be looking at, but the few calls we saw all show that no DTMF keypresses are detected by the Dialogic card.
This is most likely due to a bad DTMF tone being sent by the phone used or by the line imepdance mismatch.
Can you setup a script consisting of just a single record module and the dial in and press all the DTMF tones on your phone and then .ZIP up and post the recording of the DTMF tones as received by the Dialogic card. We can then see how the DTMF tones sound like as heard by the Dialogic card.
160126.641 6 1 state [Get Numbers 5] Number Input
160126.656 6 1 PrepareAndPlayWavAndTts start iModuleIdx=12, iPlayFileIdx=1, bMakeTtsFile=True, sSoundFileIs=
160126.672 6 1 PrepareAndPlayWavAndTTS sPlayFile=get ready.wav
160126.672 6 1 state [Get Numbers 5] Playing wav (get ready.wav)
160126.672 6 1 sOptionsXml=
160126.672 6 1 t timer clear (force=False)
160126.672 6 1 qTel add cmd_PlayStart [0,0,0,0,0][||||]
160126.672 7 1 qTel run cmd_PlayStart
160126.672 6 1 play start ok, playId=892968
160126.672 6 2 NewVgsVgm_Goto end
160129.250 19 1 ev PlayEnd 1 892968
160129.250 19 1 play end id=892968, (current ID)
160129.250 19 1 qScr add evScriptEvent 8001 EV_PLAY_FINISHED
160129.250 6 1 qScr run evScriptEvent EV_PLAY_FINISHED, iActionID=0, crn=0[892968|0|0|0|0][|||||]
160129.250 6 1 ScriptEvent EV_PLAY_FINISHED ||
160129.250 6 1 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
160129.250 6 1 path {EV_PLAY_FINISHED} not found
160129.250 6 1 iCurrReplayCount=0, iMaxReplayCount=2
160129.250 6 1 t timer set 2 sec : EV_TIMEOUT_REPLAYMSG
160131.344 4 1 timer EV_TIMEOUT_REPLAYMSG
160131.344 4 1 qScr add evScriptEvent 9005 EV_TIMEOUT_REPLAYMSG
160131.344 6 1 qScr run evScriptEvent EV_TIMEOUT_REPLAYMSG, iActionID=0, crn=0[0|0|0|0|0][|||||]
160131.344 6 1 ScriptEvent EV_TIMEOUT_REPLAYMSG ||
160131.360 6 1 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG
160131.360 6 1 path {EV_TIMEOUT_REPLAYMSG} not found
160131.360 6 1 PrepareAndPlayWavAndTts start iModuleIdx=12, iPlayFileIdx=1, bMakeTtsFile=False, sSoundFileIs=
160131.360 6 1 PrepareAndPlayWavAndTTS sPlayFile=get ready.wav
160131.360 6 1 state [Get Numbers 5] Playing wav (get ready.wav)
160131.360 6 1 sOptionsXml=
160131.360 6 1 t timer clear (force=False)
160131.360 6 1 qTel add cmd_PlayStart [0,0,0,0,0][||||]
160131.360 6 1 play start ok, playId=897656
160131.360 7 1 qTel run cmd_PlayStart
160133.891 19 1 ev PlayEnd 1 897656
160133.891 19 1 play end id=897656, (current ID)
160133.891 19 1 qScr add evScriptEvent 8001 EV_PLAY_FINISHED
160133.891 6 1 qScr run evScriptEvent EV_PLAY_FINISHED, iActionID=0, crn=0[897656|0|0|0|0][|||||]
160133.891 6 1 ScriptEvent EV_PLAY_FINISHED ||
160133.891 6 1 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
160133.891 6 1 path {EV_PLAY_FINISHED} not found
160133.891 6 1 iCurrReplayCount=1, iMaxReplayCount=2
160133.891 6 1 t timer set 2 sec : EV_TIMEOUT_REPLAYMSG
160136.047 4 1 timer EV_TIMEOUT_REPLAYMSG
160136.047 4 1 qScr add evScriptEvent 9005 EV_TIMEOUT_REPLAYMSG
160136.047 6 1 qScr run evScriptEvent EV_TIMEOUT_REPLAYMSG, iActionID=0, crn=0[0|0|0|0|0][|||||]
160136.047 6 1 ScriptEvent EV_TIMEOUT_REPLAYMSG ||
160136.047 6 1 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG,EV_TIMEOUT_REPLAYMSG
160136.047 6 1 path {EV_TIMEOUT_REPLAYMSG} not found
160136.047 6 1 PrepareAndPlayWavAndTts start iModuleIdx=12, iPlayFileIdx=1, bMakeTtsFile=False, sSoundFileIs=
160136.047 6 1 PrepareAndPlayWavAndTTS sPlayFile=get ready.wav
160136.047 6 1 state [Get Numbers 5] Playing wav (get ready.wav)
160136.047 6 1 sOptionsXml=
160136.047 6 1 t timer clear (force=False)
160136.047 6 1 qTel add cmd_PlayStart [0,0,0,0,0][||||]
160136.047 6 1 play start ok, playId=902343
160136.047 7 1 qTel run cmd_PlayStart
160138.594 19 1 ev PlayEnd 1 902343
160138.594 19 1 play end id=902343, (current ID)
160138.594 19 1 qScr add evScriptEvent 8001 EV_PLAY_FINISHED
160138.594 6 1 qScr run evScriptEvent EV_PLAY_FINISHED, iActionID=0, crn=0[902343|0|0|0|0][|||||]
160138.594 6 1 ScriptEvent EV_PLAY_FINISHED ||
160138.594 6 1 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
160138.594 6 1 path {EV_PLAY_FINISHED} not found
160138.594 6 1 iCurrReplayCount=2, iMaxReplayCount=2
160138.594 6 1 t timer set 10 sec : EV_TIMEOUT_HANGUP
160138.594 6 1 t timer set 6 sec : EV_TIMEOUT_ENTERDATA
160145.126 4 1 timer EV_TIMEOUT_ENTERDATA
160145.126 4 1 qScr add evScriptEvent 9006 EV_TIMEOUT_ENTERDATA
160145.126 6 1 qScr run evScriptEvent EV_TIMEOUT_ENTERDATA, iActionID=0, crn=0[0|0|0|0|0][|||||]
160145.126 6 1 ScriptEvent EV_TIMEOUT_ENTERDATA ||
160145.126 6 1 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA,EV_TIMEOUT_ENTERDATA
160145.126 6 1 path {EV_TIMEOUT_ENTERDATA} not found
160145.126 6 1 rv add [Get Numbers 5]{}
160145.126 6 1 rvns add [Get Numbers 5_PathTaken]{fail}
160145.126 6 1 HangupCall, source=No data entered, WorkModeScript=Running_Normal, yLineStateAppPov=[Connected], lPlayId=0, lRecId=0
160145.126 6 1 ScriptState set Stopping, (called from HangupCall)
160145.126 6 1 ls set Disconnect_Pending
160145.126 6 1 state Hanging up... [No data entered]
100455.869 6 1 state [Get Client ID] Number Input
100455.884 6 1 PrepareAndPlayWavAndTts start iModuleIdx=1, iPlayFileIdx=1, bMakeTtsFile=True, sSoundFileIs=
100455.900 6 1 PrepareAndPlayWavAndTTS sPlayFile=PayGetId.wav
100455.900 6 1 state [Get Client ID] Playing wav (PayGetId.wav)
100455.900 6 1 sOptionsXml=
100455.947 6 1 t timer clear (force=False)
100455.947 6 1 qTel add cmd_PlayStart [0,0,0,0,0][||||]
100455.947 6 1 play start ok, playId=502687
100455.947 7 1 qTel run cmd_PlayStart
100455.947 6 1 qScr run evScriptEvent TDX_CST, iActionID=0, crn=10000001[65535|0|0|0|0][DE_LCON|||||]
100455.947 6 1 ScriptEvent TDX_CST DE_LCON||
100455.947 6 1 LsGetNbrsPlayWelcMsg EV_UNKNOWN_134,TDX_CST
100455.947 6 1 path {TDX_CST} not found
100504.478 19 1 ev PlayEnd 1 502687
100504.478 19 1 play end id=502687, (current ID)
100504.478 19 1 qScr add evScriptEvent 8001 EV_PLAY_FINISHED
100504.478 6 1 qScr run evScriptEvent EV_PLAY_FINISHED, iActionID=0, crn=0[502687|0|0|0|0][|||||]
100504.478 6 1 ScriptEvent EV_PLAY_FINISHED ||
100504.478 6 1 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
100504.478 6 1 path {EV_PLAY_FINISHED} not found
100504.478 6 1 iCurrReplayCount=0, iMaxReplayCount=0
100504.478 6 1 t timer set 10 sec : EV_TIMEOUT_HANGUP
100504.478 6 1 t timer set 6 sec : EV_TIMEOUT_ENTERDATA
100504.759 19 1 ev dtmf # (268435457,35,0)
100504.759 19 1 qScr add evScriptEvent 35 #
100504.759 6 1 qScr run evScriptEvent #, iActionID=0, crn=0[0|0|0|0|0][|||||]
100504.759 6 1 ScriptEvent # ||
100504.775 6 1 LsGetNbrsRxDigits #,#
100504.775 6 1 t timer clear (force=False)
100504.775 6 1 rv add [Get Client ID]{}
100504.775 6 1 rvns add [Get Client ID_PathTaken]{fail}
100504.775 6 1 HangupCall, source=*# in GetNbrsRxDigit, WorkModeScript=Running_Normal, yLineStateAppPov=[Connected], lPlayId=0, lRecId=0
100504.775 6 1 ScriptState set Stopping, (called from HangupCall)
100504.775 6 1 ls set Disconnect_Pending
