Query Module Not Working In Hangup Script
Hi
I,m using a script that checks the content of a basic mysql table after the call is hanged-up.
senario 1 : if the query returns a row I play saveok module (this works)
senario 2 : if the query returns no entry, I would like to play "pause" module (this does not work)
when checking the logs I can see in the senario2 logs, it seems that the query module "eval_conn_agents" that I use to check the table is not even played.
Please find in attachement the 2 logs senarios and the hang_up script
Any advise please.
Thank you
logs_with_rows.txt
log_with_no_rows.txt
save_hangup_VAD.vgs
In the first trace the [eval_conn_agents] DB Query module returns some data and then the script goes to modules [Evaluate 5] and [saveOK].
In the second trace the [eval_conn_agents] DB Query module deos not return any data, and the "After Hangup Script" is then ended, as the 'fail' path is not specified in module [eval_conn_agents].
Looking at script the only path defined in module [eval_conn_agents] is this:
on {success} goto [Evaluate 5]
If you want to have script go onto another module after no data has been retrieved in response to the SQL Select statemtn you need ot specify a "on {fail} goto ..." path.
133151.281 22 1 rv add [eval_conn_agents_RowCount]{0}
133151.281 22 1 oVgmDbQuery_AdoNetCommon_Completed SqlQueryType=READER, RowsCount=0
133151.281 22 1 HangupCall, source=oVgmDbQuery_AdoNetCommon_Completed PathNotDefined, WorkModeScript=Running_AfterHangup, yLineStateAppPov=[idle], lPlayId=0, lRecId=0
133151.281 22 1 ScriptState set Idle_WaitingForNextCall, (called from HangupCall_AlreadyOnHook)
133151.281 22 1 HangupCall WorkingModeScript=AfterHangupRun.
