Guest Eric Report post Posted 02/14/2003 04:38 PM Katalina: I see that one of the recommended telephony cards is the Dialogic D/41D. I have the opportunity to purchase a D/41DHS (replaced by the D4PCIEURO). Is this just a half-size version of the D/41D, and can I use it with Katalina VoiceGuide? Thank you, Eric Share this post Link to post
SupportTeam Report post Posted 02/15/2003 04:52 AM We're not familiar with the D/41DHS. Even if it is just the half size version of D/41D then you will still have to update your installation by downloading and installing the MuLaw sound files - any recording will also be done in this format - which is a tricky standard to work with.. I'd be leaning to buying one of the cards which can work with normal PCM WAV files - the cards are listed on: http://www.katalinatech.com/suppRecomHardware.htm Share this post Link to post
