Guest fsoudbakhsh Report post Posted 08/05/2009 05:55 AM Hello, I hire a coder to write attached vbs file. it's run very well but when I used it with VG it doesn't work at all. I just carious if attached file is a VBS code or VBA code. if it is a VBA code, can VG run it? thanks for your advice. Farzad Share this post Link to post
SupportTeam Report post Posted 08/05/2009 06:39 AM Could you please .ZIP up the VoiceGuide script file (the .VGS file) in which this VBScript code is used (from within a Run VBScript module). Share this post Link to post
SupportTeam Report post Posted 08/05/2009 06:47 AM Could you also please post the vgEngine trace capturing the call. This will let us see what is happening on the system. Share this post Link to post
Guest fsoudbakhsh Report post Posted 08/05/2009 05:44 PM Hello, Please find attached file the VG file and logs files. I use to run the vbs code. thanks for your help. Farzad Share this post Link to post
SupportTeam Report post Posted 08/05/2009 08:57 PM No files were attached. Can you please try posting them again? Share this post Link to post
Guest fsoudbakhsh Report post Posted 08/05/2009 09:08 PM sorry, I forgot to push the upload button. I upload successfully and is available from the 'Manage Current Attachments' menu Thanks Farzad Log.zip Share this post Link to post
SupportTeam Report post Posted 08/05/2009 10:21 PM Trace shows that the VBScript module [FirstData] is started and the script is ran with no errors and the Run_ResultReturn function is called and returns "[FirstDataResult]{}" back to VoiceGuide. So from VoiceGuide's point of view the script runs and completes with no errors and VoiceGuide then continues onto the next module. Looks like your question is why the variable res in this statement towards the end of the vb script: vg.Run_ResultReturn $RV_LINEID, "[FirstDataResult]{" + res +"}" is empty. We can see from the VBScript that the variable res is assigned a value returned by the LpiCom_6_0.LPOrderPart COM object, within the Sub firstdata(), but the Sub firstdata() is never called in the VBScript... You should speak to the programmer as to why they are never calling the Sub firstdata() Or you could try adding a line like this: firstdata just before: vg.Run_ResultReturn $RV_LINEID, "[FirstDataResult]{" + res +"}" the firstdata line will call the Sub firstdata() subroutine. 103429.63 1 state [FirstData] Running VB Script... 103429.63 1 rv replace start (strlen>1000) 103429.63 1 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{08/05/2009 10:34:29}[$RV_DEVICEID]{1}[DlgcNetworkResource]{dxxxB1C1}[DlgcVoiceResource]{dxxxB1C1} [$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptsPath]{C:\Documents and Settings\Administrator\My Documents\IVR softwares\First Data API\Fist Data API\}[scriptPath]{C:\Documents and Settings\Administrator\My Documents\IVR softwares\First Data API\Fist Data API\}[$RV_CIDNUMBER]{} 103429.64 1 vbs run [vbs_1_1.vbs], cmd [wscript "C:\Program Files\VoiceGuide\temp\vbs_1_1.vbs" //I //T:60] 103429.77 1 Run Script waiting. iRunWait=1 (shellid=2604, process=1668) 103429.77 1 timer set 1 EV_TIMEOUT_CHECKONSTATE 103430.16 1 cl Run_ResultReturn [[FirstDataResult]{}] 103430.16 1 rvns add [FirstDataResult]{} Share this post Link to post
