D4pciuf - 2 Boards
Hi
After try using D/120JCT to incoming fax (now it is ok), now we will install 2 new boards D4PCIUFW (4 ports each) in the same machine.
How can we configure the config.xml to recognize this new 2 boards ? we plan to receive fax using it too.
Any tip or recomendation more ?
Have a look a the sample config file: "Sample Config for 12 port using analog D120JCT card.xml"
Rename that file to Config.xml and remove the last 4 <Channel> entries from that file. Resulting Config.xml will open the 8 channels on the two D/4PCIUFW cards.
