bfrank Report post Posted 08/18/2009 08:10 PM Hi. I'm using relative paths to specify scripts in the Paths tab. For example, in my IdentityFlow script, I would forward the caller to the Main script by entering: goto [../main/main.vgs|] It seems that internally, the script path is never replaced by a resolved/rooted path. It is maintained in memory as relative. This results in incorrect bahavior. For example, downstream during execution of the fourth script, the ScriptPath RV contains the wrong value. In addition, the LastModule RV contains the following: C:\IvrRoot\Scripts\IdentityFlow\..\main\..\accessNumberFlow\..\main\main.vgs|TransferToRep This isn't a showstopping problem, I don't really need to use relative paths, but it sure would be convenient, and besides you should know about buggy behavior. So here you go. Thanks. Share this post Link to post
SupportTeam Report post Posted 08/19/2009 08:20 AM Thanks for reporting this. We've modified the vgEngine code appropriately and in future v7.1 releases the $RV_PreviosModule will contain the resolved path which will not include any 'relative' \..\ type expressions. Share this post Link to post
