Setting The Default Script For The Line
Jose wrote:
I installed successfully VoiceGuide version 7 with our existing Dialogic 4PCI/U card, using the Dialogic SR6.0 SU184 drivers from your website. I tested our four (4) phone lines using the demo application Credit card, and it works fine in the test PC.
However, I was unable to change the Inbound Script in the VoiceGuide Status Monitor. How do you configure the script to be run in VoiceGuide 7?
In VoiceGuide v7 the default starting script for each line is set in the Config.xml file.
The Config.xml file is located in VoiceGuide's \Config\ or \conf\ subdirectory.
