bfrank Report post Posted 09/22/2009 06:40 PM I'd like to install the Script Designer on a dev machine without all the server-side applications. The wizard doesn't provide an advanced step that allows you to select which applications to install. Currently all development has to happen on the server but that isn't feasible going forward. Installing the whole thing on a dev machine is not a preferred option. I tried running the vgScriptDesigner from a remote share but it didn't work. Could you give me some guidance as to what dependencies are needed on the local machine? Share this post Link to post
SupportTeam Report post Posted 09/23/2009 05:37 AM At this stage there is no separate 'Script Designer Only' install. The simplest approach is to run the main install and then just disable the VoiceGuide services so that they do not attempt to start on a system that does not have Dialogic cards. Services can be disabled in Control Panel -> Administrative Tools -> Services. Share this post Link to post
