jewillis Report post Posted 09/30/2009 05:23 PM I have upgraded to vgEngine version : 7.1.3555.27455 (RELEASE Build) created on : 2009-09-25 14:15:03.60 Everything worked prior to the upgrade scripts used for inbound calls are crashing VG with the below error in the Application Log NET 2 Runtime Error Time 11:53:20 Faulting application vgivrservice.exe, version 7.0.9.0, stamp 4abcd0c2, faulting module msvcr90.dll, version 9.0.21022.8, stamp 47313dce, debug? 0, fault address 0x000538cc. followed by Application Hang Time 11:53:44 Hanging application vgLineStatus.exe, version 7.0.0.0, hang module hungapp, version 0.0.0.0, hang address 0x00000000. I have VG on two separate servers in two different locations and i get the exact same error on both machines I run Windows 2003 SP2, SQL server 2005 Attached are logs and the sample script i used. I also used a test script with just a record object and that crashed the system thanks logs_and_script.zip AcceptRequests_test.vgs Share this post Link to post
SupportTeam Report post Posted 09/30/2009 09:53 PM Could you please .ZIP up and post a vgEngine log file from before the update to _090925 version was made. We can then see which version you had on system beforehand (which was working for you) and can look at the changes made between those two versions. Share this post Link to post
jewillis Report post Posted 09/30/2009 10:09 PM On server 1 the last version that was working with inbound scripts was vgEngine version: 7.0.2940.15884 (RELEASE Build) I upgraded from that to vgEngine version : 7.1.3555.27455 to be consistent with server 2 (below) On server 2 the last version that was working was vgEngine version: 7.0.3427.32874 (RELEASE Build). I did not use inbound scripts, so I can not tell if they were working. This was upgraded to vgEngine version : 7.1.3555.27455 to fix the escalation issues After both serves were upgraded they had the identical issues. I have rolled back to 7.0.2940.15884 - sacrificing escalation for stability Share this post Link to post
SupportTeam Report post Posted 09/30/2009 10:11 PM Could you also please .ZIP up and post the ktTel trace as well (the one capturing the error). Share this post Link to post
SupportTeam Report post Posted 09/30/2009 10:58 PM Thanks for the ktTel trace. The trace showed that there was a problem in the RECORD type module.We have now fixed this Record module issue and the version with this fix is available for download here: [old link removed] Share this post Link to post
jewillis Report post Posted 09/30/2009 11:03 PM you guys are good. I will install it tonight. Your support is the best This is why i am getting ready to purchase an additional 92 licenses in addition to my existing 92 Jeff Share this post Link to post
jewillis Report post Posted 10/01/2009 02:12 AM The fix version seems to have resolved the issue Thanks, Jeff Share this post Link to post
