Specify Donotcall List With Outdial_New.xml?
How do we specify a donotcall.txt file when loading the dialer with OutDial_new.xml and not the Dial List Loader?
Right now the Do Not Call screening list is selectable if the calls are loaded using the Telephone Number Loader application only.
If loading calls using other methods (COM/WCF/XML/Direct/etc) it is up to the task doing the call loading to ensure that the number loaded is pre-screened against do not call etc lists.
If you require that 'do not call list' screening be built into VoiceGuide when loading calls from XML or other sources then please email sales@voiceguide.com with details of your request.
