Wcf From Php
Can you post a simple PHP script that connects to the voiceguide WCF and echos the status of the ports?
All of the help I have seen in this forum refers to the example script which is in C.
I do not have a C compiler, I would simply like to see a short script that connects and prints the status.
This should amount to only a few lines of code, so I hope you will consider it.
Also, is there a reference or a way to get a list of the interfaces that voiceguide exposes to WCF?
I have used WCF with other web services, and have tried a script similar to this one that I have used before, with no luck ...
<?php
header('Content-Type: text/plain');
echo "WCF Test\r\n\r\n";
$client = new SoapClient('http://gamma/wcftest/MathService.svc?wsdl');
$obj->x = 2.5;
$obj->y = 3.5;
$retval = $client->Add($obj);
echo "2.5 + 3.5 = " . $retval->AddResult;
These below ones are the WCF implemented services. Try connecting to these:
http://localhost:7131/PortCommandLink?wsdl
http://localhost:7131/PortStatus?wsdl
The PortStatus one is the that you shoud be using to get port status information.
NB. other ones supported are:
http://localhost:7131/AcdService?wsdl
http://localhost:7131/LineCommandLink?wsdl
the WCF service host base addresses are defined in vgIvrService.exe.config - so you can change the base addresses and bindings there if you'd like.
