Telephone Number Loader - Unexpected Error, Quitting
Hi All,
We've downloaded and installed VoiceGuide for TAPI v5.2.5049. After configuration setup we have a problem in Telephone number loader when we click dial an error msg pops up "Unexpected error; quitting". Do anyone have faced similar kind of issue? If anyone have faced kindly advice us please.
Thanks in advance
cheers
R.Raju
So the error occurs not during installation, but when running the Telephone Number Loader application, correct?
Yes, you are right. Do you have any idea about this issue?
We've changed the topic to reflect the actual issue.
Which version of Windows are you using?
Could you please post a copy of VoiceGuide's Debug Printout which captures the Telephone Number Loader startup, this will allow us to see what happened.
[Log]
VoiceGuide=0
NumberLoader=10
VoicemailManager=0
EmailSender=0
TapiWrapOcx=0
SapiWrapOcx=0
Then start the Telephone Number Loader app.
Please post the traces.
Also, if you are doing outbound dialing then it's recommended to use a Dialogic card (and hence use VoiceGuide v6 or v7). Only Dialogic cards deliver decent results for outbound dialing applications.
